WTB Rear MT Differential for 4.08s
Old Jul 7, 2013 | 12:28 AM
Brainchild's Avatar
Brainchild
Category: Drivetrain
Price: $1
Part fits: 2010+ G37 Coupe, 2008-2009 G37 Coupe, Other Model G's
Location (State/Prov): ID
While I wait for my 4.08 ring and pinion to show up I thought I'd use the time to locate a used rear diff. IIRC, I need a rear differential with VLSD from an 08-current G37 Coupe 6-speed. If anyone has one for sale or know where I can find one, let me know!
Old Jul 7, 2013 | 02:38 AM
G37Sam's Avatar
G37Sam
A 350Z or a 370Z MT diff will also do btw. Good luck.
Old Jul 7, 2013 | 11:38 AM
Brainchild's Avatar
Brainchild
Thanks, Sam. Now that I know one from a 350Z will also work I think I'll buy that since they're significantly cheaper than one from a 370/G37. Then I'll use the money I saved to replace the used guts with a new install kit.
Quick question: other than having to be a MT, are there any other requirements of the diff to work? Base or Sport model?
Old Jul 7, 2013 | 12:34 PM
G37Sam's Avatar
G37Sam
Your driveshaft flange has three bolts and a coupler, the MT diff will have a 4 bolt flange and no coupler. So you'll need a rear half of a G35 driveshaft with the 4 bolt flange for them to mate.
Old Jul 7, 2013 | 12:56 PM
Brainchild's Avatar
Brainchild
I should have mentioned I have a G37 with 6-speed MT and a GTM Aluminum Driveshaft. So any 350Z rear diff should bolt right up without any modifications, correct? I just wasnt sure if it mattered that the 350Z rear diff was from a base or sport model.
Old Jul 11, 2013 | 11:24 PM
Brainchild's Avatar
Brainchild
Before I drop a ton of money on it, I need expert help to find out if this 350Z rear diff will fit my 08 G37 Sport Coupe without any modifications. I'm going to be installing the 4.08 ring and pinion into the 350Z rear diff and using a GTM Aluminum Driveshaft.
http://www.ebay.com/itm/04-09-350z-Z-Roadster-VLSD-LSD-3-5-Differential-Z33-/160971070473?pt=Motors_Car_Truck_Parts_Accessories&hash=item257a9f9c09&vxp=mtr
03-08 350Z (model unknown)
6-Speed MT
VLSD
Old Jul 12, 2013 | 08:32 AM
G37Sam's Avatar
G37Sam
Did you get an MT or an AT Driveshaft?
Old Jul 12, 2013 | 09:48 AM
Brainchild's Avatar
Brainchild
MT Driveshaft.
Old Jul 18, 2013 | 11:47 AM
Brainchild's Avatar
Brainchild
Nevermind. Found one from a G37.
charneco
Feb 21, 2016 11:11 PM
m3clubracer
Sep 13, 2015 09:01 AM
G37S-K52
Southern California
Sep 11, 2015 01:10 AM
Sway_NV
22
Aug 29, 2015 04:58 PM
