FS GTM Stg2 Turn Key TT Kit
Old Jun 21, 2013 | 09:06 PM
DPE G's Avatar
DPE G
Category: Engine - Power Adders
Price: $6500
Location (State/Prov): FL
Ok so as you may have seen this kit was originally listed as a stage 1 and I was upgrading to a stage 2. After removing my original turbos I noticed them being the same size. I have called and confirmed with Sam@GTM that the turbos I had were already the stage 2 components. So this kit is now being re-listed as a stage 2. My loss is your gain, this is a great deal on a great kit with a lot of new pieces. I will lay the entire kit out if it does not sell before I have time to do so. But here are some pictures to show that both kits contained the .86 a/r stage two turbos, good for up to 700hp according to GTM.
If anyone is interested in it, I can have the pipes powdercoated whatever color you want for $150 and the BOVs for an aditional $75.
Retail on this kit is $8495, save yourself $2000 for a kit that is barley used.
Below is a description of all the components of the kit :
Cast Ductile Iron Exhaust Manifolds And Turbine Housing *NEW
Pre-Bent Stainless Steel Heat Shields *NEW
Exhaust Manifold Install Hardware Kit *NEW
4-Ply High Resistance Nomex Silicon couplers
Stainless Steel T-Bolt clamps
3.5 x 13 x 24 Bar and Plate Core Intercooler Rated 1000hp
GTM Steering Coupler *NEW
Polished Stainless Steel and Tig Welded Piping **Custom Powdercoat Available
Pre-made steel braided oil and coolant Supply & Return lines
Garrett's Twin ball bearing water & oil cooled turbocharger
Cold Air Intake System (using k&n filters)
TiAL 50mm Blow-off Valve
HKS Internal Wastegate Actuators
All Necessary Hardware and Installation Instructions
GTM Custom mapped plug-in And play engine management for optimum engine tune and power .
GTM Basic fuel system with Denso 600cc Injectors and Walbro 255 Fuel Pump
**Will also include BRAND NEW HKS EVC-S EBC for $350 more!
As we all know GTM has a great deal on the MHI kit right now, however they are inferior journal turbos, not the Garrett dual Ball Bearing turbos.
Hard to get pictures of it but everything you need to bolt and go will be included. And the GTM instruction manual as well.
Old Jun 22, 2013 | 02:18 PM
Kevalteam's Avatar
Kevalteam
GLWS~~ looks beautiful~~~ ^^
Old Jun 22, 2013 | 08:57 PM
DPE G's Avatar
DPE G
Thanks, also open to trades +cash for parts of decent value that I can turn around and sell, makes it a little easier on the pocket book for the buyer.
Old Jun 22, 2013 | 09:23 PM
Alkatraz's Avatar
Alkatraz
Awesome price. MHI kit $$$ but with Garett turbo's. You will be making someone very happy! GLWS!
Old Jun 23, 2013 | 12:34 PM
DPE G's Avatar
DPE G
Yes Ball Bearing > Journal turbos
Old Jun 24, 2013 | 10:58 AM
DPE G's Avatar
DPE G
bump, who is ready to make some power?
Old Jun 25, 2013 | 08:57 AM
DPE G's Avatar
DPE G
Turbo Tuesday bump
Old Jun 25, 2013 | 09:31 AM
G37Sam's Avatar
G37Sam
Man where were all these deals when I had my VQ engine!
Old Jun 25, 2013 | 12:14 PM
DanGer's37's Avatar
DanGer's37
Wish I had a spare 6k laying around
Old Jun 26, 2013 | 08:28 AM
DPE G's Avatar
DPE G
Humpday!
Old Jun 26, 2013 | 12:40 PM
BANNISTER's Avatar
BANNISTER
trade weds kranze wheels plus 2300
Old Jun 26, 2013 | 12:58 PM
WARAT's Avatar
WARAT
If only I could trade you my camera gear for the kit. its worth >6k after you sell it.
Bump!!
Old Jun 26, 2013 | 01:53 PM
Tiny's-G37s's Avatar
Tiny's-G37s
What was the psi at 485hp? Also does this kit fit with the front crash bar?
Old Jun 26, 2013 | 02:43 PM
DPE G's Avatar
DPE G
No front "crash bar" (5mph bar) is removed, as you can see in the pictures up top. It could be modified to work, and I've seen people weld up a tubular bar, but at that point I'm not sure how much help it would be so I just removed it completely.
485 was between 9-10psi, spring pressure from the wastegates, never used the boost controller. As a matter of fact I do have a Manual Boost Controller I will include with the kit that I forgot I had.
Old Jun 26, 2013 | 04:59 PM
soolman32's Avatar
soolman32
This is the year for going boost and this is definitely a sweet deal! GLWS Nick!
