FS Exedy Clutch + Flywheel Stage 1 NEW
Old Oct 31, 2011 | 05:36 PM
Modme's Avatar
Modme
Category: Engine - Power Adders
Price: $850
Location (State/Prov): NY
Have a set of Exedy flywheel + clutch for G37, 370z, G35, 350z VQ35HR and VQ37VHR engines. This is brand new and never used. 0 Miles on it and never mounted.
Exedy is the biggest manufacture of OEM clutches. This setup is going to be the most OEM like and street friendly. Holds 40% more clamping force than stock and lighter flywheel.
Part # Torque Capacity Disc OD Disc Spline Flywheel Weight
06807 + NF05 376 ft./lbs. 250mm 24 18.5 lbs.
Includes new pilot bushing and alignment tool!
$850 shipped to you.
More info:
EXEDY organic racing clutches only use premium friction materials that are resistant to slippage and burst. Increased clamp loads give the necessary capacity to handle modified engines. This is the preferred clutch for street and light horsepower track use. Driveability is similar to the stock clutch. Pedal efforts will be slightly higher because of the higher clamp loads. All of our clutch discs have spring center dampers to reduce drivetrain shock.
sold to BiggieC!!
Old Nov 8, 2011 | 08:02 PM
Modme's Avatar
Modme
bump!!!!!!
Old Nov 15, 2011 | 10:29 AM
Modme's Avatar
Modme
who needs a new clutch?
Old Nov 20, 2011 | 11:51 PM
Modme's Avatar
Modme
bump!!!!
Old Nov 30, 2011 | 07:23 PM
BiggieC's Avatar
BiggieC
Sold to me! can't wait
Kojack
Oct 9, 2015 05:53 PM
stevo4756
Oct 9, 2015 01:54 AM
r0cketm0nkey
Sep 27, 2015 01:34 PM
