My new +5 stance
Old Nov 22, 2011 | 05:28 PM
  #31
Doggy's Avatar
Doggy
Originally Posted by Presto
Nice work on the DIY.
Is that the fresh ta def trunk? How is the fitment? Gaps around the edges? Can people still buy it?
It is a fresh ta def trunk with a cf lip, The fitment isnt the best, you need to cut the factory bracket to make for room for sliding, and it is discontinued due to this reason Im pretty sure.
Is that the stillen or ait roof spoiler? How is the fitment?
Need more high res pics
The fitment isnt the best, you need to cut the factory bracket to make it fit right, and its discontinued. But yes its the fresh ta def trunk
The roof spoiler is an ebay one, and the fitment is perfect!
Originally Posted by P Casey
I really like it man, especially how the front looks. +20 on our cars always looks a little tucked.
thanks man, ya the +20 looked stupid imo compared to the +25 rear, Now its about even.
Originally Posted by xxryanlamboxx
I have my coils at max stiffness on the dampening and it still hits so i recommend getting the stance coilovers with true rear setup and swift springs.
What coils were you on? And when you say true setup, you mean shock and springs in one? I was looking at bc. I heard stance is the same company
Old Nov 22, 2011 | 05:33 PM
  #32
xxryanlamboxx's Avatar
xxryanlamboxx
Yea true setup is shock and springs on one. and i have bc br coilovers right now with 12k 10k spring rate. but i'm planning on getting stiffer spring rates and switching the rear to a true setup.
Old Nov 22, 2011 | 05:37 PM
  #33
TastefullyDoneG's Avatar
TastefullyDoneG
Originally Posted by VossenG37S
I know about stretching I've ran +5/15 before w that exact tires size and yes the ride is that bad in comparison w what I have now, after shredding my tire on the highway after a few hundred miles I just won't mess w that again! It sure looks good but for a daily driver it's just something I personally would never recomend again. He's going for looks so thats great cause it looks good just saying I know it's his DD so it's not the best option . Sacrificing tire life and riding around at risk is not my thing, GL to you brotha just my .02 !
Has absolutely nothing to do with having dampening, u only want dampening to make it stiffer Wich making it stiff with stretch tires = to a ****tier ride! My tanabe Coils ride better then stock slammed even! Call it what you want I have ran plenty of set ups to judge better from experience . I had my camber within specs as well and yes it's a **** ride regardless ! If a 245 tire on a 10.5 is not a risk then enjoy it , looks rediculous IMHO as rides horrible on top of that rides rediculous. Btw rear tire is what popped after only 500 miles camber was at -2.1 and was slammed w tanabe coils! GL guy I said all I wanted
Really? How can you honestly tell someone that it has nothing to do with dampening? People set it to there liking.. reason why people invest in true coilovers.. Non dampening means you got no choice but to ride what they throw at you which some people don't like and they complain about the ****ty ride.. Of course tanabe would ride better then stock slammed since I don't even know how you can even slam a stock suspension besides cutting the springs? Only if you are talking about buying after market springs and riding on stock shocks... but of course it would ride like **** cause the stock shocks can handle so much before they blow.. 245 on a 10.5 isn't even that bad. Plenty of people do it hear and the only idiots who actually run into problems.. blow outs, side bubbles etc are the one who don't pay attention to there PSI.
Old Nov 22, 2011 | 05:39 PM
  #34
TastefullyDoneG
What coils were you on? And when you say true setup, you mean shock and springs in one? I was looking at bc. I heard stance is the same company[/quote]
If you get coils and get stuck between bc and stance.. get stance I had both setup and liked stance a lot better. Yes true setup springs and shock is together.
Old Nov 22, 2011 | 05:43 PM
  #35
xxryanlamboxx
If you get coils and get stuck between bc and stance.. get stance I had both setup and liked the ride for stance a lot better. Yes true setup springs and shock is together.[/QUOTE]
Yea i would get stance if i had to redo it again. i'm thinking about selling my bc to get some stance coilovers. they are made for what you are wanting to do Doggy. make sure you get the true setup though. definitely gonna be alot better and more comfortable.
Old Nov 23, 2011 | 12:22 AM
  #36
Doggy's Avatar
Doggy
I heard that true coils weren't meant for these cars and can cause problems in the long rum. Some guy made a whole thread on my350z about it. What doing rates do you suggest on the bc
Old Nov 23, 2011 | 12:33 AM
  #37
jamesshifflett's Avatar
jamesshifflett
Great job Doggy! U know I was skeptical but DAMN, it turned out sick! Keep it up
Old Nov 23, 2011 | 02:02 AM
  #38
tWistedMissiOn's Avatar
tWistedMissiOn
Hey Doggy, you have the link to this?? My suspension mod that i will do will be true coils.... whats bad in the long run? Thanks man.
Old Nov 23, 2011 | 05:42 PM
  #39
Doggy's Avatar
Doggy
I'll try to find the link
Old Nov 24, 2011 | 01:02 PM
  #40
Doggy's Avatar
Doggy
Here I found this
Not so much the spring rates, my concern is with the kinematics.
I thought that the spring mounted directly on the upright would cause an issue in lateral weight transfer, where the kinematics would create a higher wheel rate from reaction torque placed through the upright, whereas the moment would not exist if the load were on the lower control arm. I could not confirm this through ADAMS modeling, though I still suspect there is more occurring than ADAMS modeling can show. (ADAMS does have some flaws)
That being said, what I can confirm is this:
The spring mounted on the damper assembly WILL cause a linear spring to be progressive, since the wheel rate is a function of spring rate multiplied by the cosine of declination. Since the spring will move as an arc, the cosine function will increase through travel, affecting spring rate.
The damper's upper mount is not idealized for carrying the lateral load transfer if the spring is also utilizing this mount. The direction of the mounting bolts is perpendicular to this moment to allow flex, if the weight is transfered through this position, a wider mount would be better, such as the front upper mounts. I would not be surprised, without reinforcement, if the two upper mount bolts would break under high lateral loads.
The anti-squat on the 350Z is very high. The reaction torque in the longitudinal plane from acceleration forces is very pronounced, and acting through the top of the upright increases this affect, since there is a static moment created by the damper's mount from the upright's center. This is the primary reason spring rates on the Z must be fairly low- to accommodate the high wheel rate found under acceleration. If the traction arm could be adjusted to a new position, which I have seen done by re-welding the chassis mount, then the deficiencies of the spring rate in the damper location (in terms of wheel rate and anti-squat) could be resolved.
The JUN car you posted does not use the stock kinematics, and the traction arm is missing altogether. The Nismo race car does not appear to use the stock mount and also has adjusted the traction arm.
I would imagine that the upper mount of the Nismo car has been re-worked to survive the high lateral loading from competition.
Inverting the rear damper would be the best way for the damper to endure the lateral loading, if the spring is mounted around it. It would also better handle the friction increase in the damper's motion from lateral loading.
Mounting the spring in the OEM position, provided stock kinematics are considered, reduces this friction considerably (60% according to Nissan) and allows the spring rate to better match the wheel rate by reducing the affects of anti-squat (compared to a damper mounted spring).
I would not run the spring on the damper without the changes I mentioned, and have seen no benefit in ADAMS modeling, or using Optimum K, with using a spring mounted on the damper. If the changes I outlined were made, then mounting the spring on the damper has the benefit of reducing unsprung mass, and reducing the motion ratio, but these are only benefits if the kinematics are properly dealt with first.
That's really all I have to say about it. Do what you want, but be careful comparing photographs of cars who's suspension design you know nothing about. There is more than meets the eye to proper design. Nissan did it the way they did on purpose.
Will
05-02-2008, 04:37 PM * #8
Old Nov 24, 2011 | 01:39 PM
  #41
xxryanlamboxx
the spring rates that i was suggested of running would be 14k front and 18k rear.
Old Nov 24, 2011 | 08:44 PM
  #42
huwee06's Avatar
huwee06
Never thought of what you mention Doggy, I have fortune auto 500 w/swift springs true coils rated 7k for rears. Took her on some twisty and it rode great so far hope it the top mounting bolts don't crap out like you mention in the long run.
Old Nov 25, 2011 | 03:19 AM
  #43
Kuro's Avatar
Kuro
Looks good Doggy, What is your center fender height from ground front and rear?
Is this the same one? Strafe Automotive Infiniti G37 Coupe Trunks AMS Trunk Fiberglass
Old Nov 30, 2011 | 12:12 AM
  #44
zir's Avatar
zir
car looks good! very nice actually! but +1 on what vossen said, i dd my car dropped on s-techs stretched tires no camber kit. sometimes i don't even wanna drive on the freeway lol! scary sometimes, and tires popped on me 2 times 225/40 on 9.5 and 1 time with 245/35 on 10.5... maybe stockton, ca roads just suck i don't know lol! but again nice ride broham!
Old Dec 1, 2011 | 03:03 PM
  #45
Doggy's Avatar
Doggy
Last time I measured it was about 26, but it's lower now.
No it's fresh ta def. That trunk is new ^
dam how hard did you hit bumps ^ that's a bit scary. Could be your wheel has a leak
