Varrstoen Wheels are in!
Old Mar 21, 2011 | 03:12 AM
jc562's Avatar
jc562
nice. cant wait to see the finished result i wanted this set up in gunmetal but im worried of how much work it would take to make them fit right.
Old Mar 21, 2011 | 12:39 PM
cdeez's Avatar
cdeez
nice..i can't wait to see it with a drop...oh i don't know if those are the correct tires sizes brotha. im on h & r and im running 35 in the front and 30 in the rear, im pretty sure you should be running 30 series tires so you don't get any rubbing.
Old Mar 21, 2011 | 10:32 PM
zir's Avatar
zir
the camber h&r will give you + your set up... your doing it right bro, can't wait to see it!
Old Mar 21, 2011 | 10:53 PM
Stanced370Z's Avatar
Stanced370Z
ur going to need some rear camber arms for that. the -4 camber the H&R's r going to give u isn't going to cut it. You need more or a fender pull.
Old Mar 21, 2011 | 11:06 PM
P Casey's Avatar
P Casey
Ya I was gunna say. U have to do sumthing.
Old Mar 21, 2011 | 11:09 PM
BooSa37's Avatar
BooSa37
Like I said on my previous post on here, H&R n those wheels won't work.
Old Mar 21, 2011 | 11:22 PM
myk1013's Avatar
myk1013
It could work. Check out zir's ride with same wheels and specs but on S-techs.
Old Mar 21, 2011 | 11:26 PM
BooSa37's Avatar
BooSa37
I had H&R with the stock wheels/my cv1 there is def no gap in the rear with those springs. Front has just a slight gap, so honestly super aggressive offsets won't work without doing some work IMO. I could be wrong but I'm just talking from my experience.
Old Mar 21, 2011 | 11:28 PM
zir's Avatar
zir
i'm pretty confident he won't have to. i have the same wheels. and the negative camber s-techs gave me were just fine. h&r drops more which would probably give a tad more neg. camber. as for h&r being a little lower than s-techs, i've tried putting 3 of my friends... bout um, 160lbs each in the car which of course filled the remaining seats. no rubbing at all... maybe only the rear plastic mud guard... sometimes! anyway we'll just have to see. so for now... i hope it works!
i had my bro take a picture of mine while he puts the jack down. and yes i was scared but it worked.
Old Mar 21, 2011 | 11:48 PM
P Casey's Avatar
P Casey
Nice, you have 10.5 in back and 9.5 in front as well?
Old Mar 22, 2011 | 12:18 AM
P Casey's Avatar
P Casey
yup, you did. then im assuming it will work.
Old Mar 22, 2011 | 01:27 AM
g37jatt's Avatar
g37jatt
Putting the springs on in a couple of days, we will know if it's going to work! I got confidence it will. Zir's done it!
Old Mar 23, 2011 | 02:48 PM
CleanAsFuhh's Avatar
CleanAsFuhh
DONT GET H&R trust me when i say they wont work!!! the only way your going to pull this one off is with coils and neg. camber for sureeeeeeeeeee.
Old Mar 23, 2011 | 09:26 PM
  #29
jc562's Avatar
jc562
actually this wasnt the setup i was looking at its similiar but i was looking at 0 offset anyone know if it will fit with eibach
Old Mar 23, 2011 | 10:26 PM
  #30
myk1013's Avatar
myk1013
0 offset??? I doubt it will work with Eibachs.
