Unorthodox Racing Crank Pulley (Ultra Sc)
Old Aug 20, 2008 | 09:07 AM
Kidcane's Avatar
Kidcane
Florida G Club
Yeah what is the weight difference on these from stock?
Old Aug 20, 2008 | 09:09 AM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Stock is like 8 lbs and some ounces... UR is 1 lb and some ounces...
Old Aug 20, 2008 | 09:10 AM
MaxToTheG37
Actually its : STOCK 8lb 4.3 oz compared ......... UR at just 1lb 5.2oz!!
Old Aug 20, 2008 | 11:04 AM
vinnys coupe's Avatar
vinnys coupe
cool, keep us posted max
Old Aug 20, 2008 | 11:19 AM
MaxToTheG37
no prob....
I have found out tho that for before/after dyno numbers... I will have to dyno ... install... then drive for a couple hundred miles and dyno again...per UR.
Old Aug 20, 2008 | 11:30 AM
Buddy Revell's Avatar
Buddy Revell
Originally Posted by EZDozzit
Thanks for doing this - before/after dynos. Any risks related to going with the lighter pulley? Seems to me I read a thread or two a while back on my350Z that mentioned something to the effect that our engines components are perfectly balanced... and doing something like this throws that balance off which could result in internal damage long term.
Yeah, there was a huge debate on g35driver about pulleys. Some interesting points here: http://g35driver.com/forums/reviews/...ht-pulley.html . Hopefully, we'll see some solid gains with the UR/Stillen pulley.
Old Aug 20, 2008 | 11:31 AM
MaxToTheG37
Originally Posted by Buddy Revell
Yeah, there was a huge debate on g35driver about pulleys. Some interesting points here: http://g35driver.com/forums/reviews/...ht-pulley.html . Hopefully, we'll see some solid gains with the Stillen pulley.
Lets call the UR pulley so people dont think its 2 different products... just for the sake of being simple...
UR= Unorthodox Racing
Old Aug 20, 2008 | 12:06 PM
UNV-IT46's Avatar
UNV-IT46
should be interesting
Old Aug 20, 2008 | 12:17 PM
LAG37's Avatar
LAG37
dyno!
Old Aug 20, 2008 | 12:59 PM
bboysteele's Avatar
bboysteele
no prob....
This I don't understand. Why would you need to drive a couple hundred miles to see a gain? The only way this would be is if a management system needs to adjust to the new pulley. The ECU can be reset so that is not the problem. I wonder if another control unit needs to adjust for there to be gains.
Old Aug 20, 2008 | 01:08 PM
MaxToTheG37
I dont either... Sharif says it should be instant at Wide open Throttle... So Ill do it before/install/after like I had planned.
Old Aug 20, 2008 | 01:34 PM
Buddy Revell
Yeah, I'm wondering about this too. Maybe we should ask GTM, Cobb, Motordyne, or Technosquare about this, since they have a wealth of technical knowledge about the VQ engine.
Old Aug 20, 2008 | 02:08 PM
MaxToTheG37
guess you missed my previous post or you dont think sharif knows VQs...
Old Aug 20, 2008 | 02:27 PM
  #29
finagle69's Avatar
finagle69
yeah, in my mind, the most result you would see would be from immediately flooring the car right after first ignition after the install BEFORE the ECU does anything to counteract it.
Old Aug 20, 2008 | 02:31 PM
  #30
LAG37's Avatar
LAG37
max how much did u get this for?
