Can anyone say Volks....
Old May 12, 2008 | 10:53 AM
  #181
JmT's Avatar
JmT
CLEAN! CLEAN! Luv'n It!
Old May 12, 2008 | 11:10 AM
  #182
UNV-IT46's Avatar
UNV-IT46
Originally Posted by TunedG37
At around 2pm the weather outside is HOT as ****...So lets see if at around 5pm would be a good time. It's not so hot, and anyways the sun doesn't start going down until around 730-8pm...I'll see what the photographer says. I'll keep you updated.
5 is fine with me, i agree its hot as *****...
Old May 12, 2008 | 11:15 AM
  #183
UNV-IT46's Avatar
UNV-IT46
thanks
Old May 15, 2008 | 11:25 PM
  #184
UNV-IT46's Avatar
UNV-IT46
never finished posting the rest that showed fitment...
Attached Thumbnails Can anyone say Volks....-cimg1969-copy.jpg   Can anyone say Volks....-cimg1970-copy.jpg   Can anyone say Volks....-cimg1971-copy.jpg   Can anyone say Volks....-cimg1972-copy.jpg   Can anyone say Volks....-cimg1973-copy.jpg
Old May 15, 2008 | 11:26 PM
  #185
TerribleONE453's Avatar
TerribleONE453
your car is a cam *****
Old May 15, 2008 | 11:34 PM
  #186
UNV-IT46's Avatar
UNV-IT46
final two.
after some time driving now and removing the wheels again on the lift and investigating i am not rubbing anywhere in the wheel wells front nor rear. I did cut away some carpet in the rear which i had to or else i woud have rubbed. I am not rubbing the metal bumper bracket in the rear that many others have been rubbing. I am running a +33 rear so i should be but there are two factors working in my favor. One is i went with 19"s instead of 20"s. second is i went with a 30 rear sidewall which is what you should run if you are using 20"s not 19"s. I should be using a 35 rear. but since i went down to 30 it gave me the extra room to keep clear of the bracket. the fronts are a 35 which should be a 40 which also gives me more space. I rubbed the stock plastic in the front fender wells on my oem wheels and tires with the 45 front. not with the wider wheel, more aggressive offset but smaller side wall i dont rub. I do rub the little mud guards that are in front of the front wheels. the small black plastic flaps that hang down. When hitting a dip in the road at speed or the gutter's down at the end of my drive way i scrape that part. but thats it.
Attached Thumbnails Can anyone say Volks....-cimg1974-copy.jpg   Can anyone say Volks....-cimg1975-copy.jpg
  #187
UNV-IT46's Avatar
UNV-IT46
she loves attention what can i say
Old May 15, 2008 | 11:49 PM
  #188
rmatthews81's Avatar
rmatthews81
Sweet Car man. One of the best I have seen.
Old May 16, 2008 | 10:01 AM
  #189
Kidcane's Avatar
Kidcane
Florida G Club
Damn I thought I was running some neg camber. I bet you hug the corners nice but does your car float at high speed on the straights?
Old May 16, 2008 | 11:56 AM
  #190
UNV-IT46's Avatar
UNV-IT46
handles on rails for sure, straight line isnt bad but high speed ya its gets a slight high speed searching
Old May 16, 2008 | 04:42 PM
  #191
FlameOn's Avatar
FlameOn
Photobucket please.
Old May 16, 2008 | 11:59 PM
  #192
12fear's Avatar
12fear
Very nice RIMs, Are you running back spacers on the rear?
Old May 17, 2008 | 03:36 AM
  #193
UNV-IT46's Avatar
UNV-IT46
no..
Old May 17, 2008 | 02:47 PM
  #194
Protein Shakes's Avatar
Protein Shakes
UNV, how much negative camber do you have your car set at...-2 to -2.5?
Old May 17, 2008 | 04:52 PM
  #195
Emon Crew's Avatar
Emon Crew
How big are the lips on the front vs the lips on the back wheels?
