Modded G37's post Pics HERE!
Old Sep 28, 2007 | 03:10 PM
  #76
GiGGaplease's Avatar
GiGGaplease
evil skiny, your car is sickkk!
Old Sep 28, 2007 | 03:54 PM
  #77
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Some cross drilled rotors would look good behind those wheels.
Old Sep 28, 2007 | 04:41 PM
  #78
evil skiny's Avatar
evil skiny
Yeah stillen sells 14.25 front cross drilled rotors, also there true dual cat back system is out now.
Old Sep 28, 2007 | 08:17 PM
  #79
Wicked_limitz's Avatar
Wicked_limitz
Originally Posted by GodZilla
OK my teaser.
wow, already? how many miles do you have lol
Old Sep 29, 2007 | 06:10 PM
  #80
DrJones's Avatar
DrJones
Originally Posted by finagle69
@NAM; i have no idea what bulb size the glove box light is. it's extremely small though.
all the other bulbs that i replaced are 194's
finagle69:
paid a visit to superbrightleds.com and just did a quick search for "194" it brought me to this link
http://superbrightleds.com/mini-wedge.html
Of all the bulbs listed which one did you choose that worked for the G37? I appreciate your help as this will keep me from purchasing the wrong ones. Thanks.
Old Sep 29, 2007 | 06:17 PM
  #81
DrJones's Avatar
DrJones
I'm sure this is posted somewhere but I pulled this from the superbrightleds.com website. It's the info for the lighting on the 07 Coupe which I am sure the bulbs are the same in the 08. If this is true than anyone wanting to switch out their bulbs should be able to use the reference chart below. If I am wrong than someone let me know. Cheers.
2007 INFINITI G35 (Coupe)
High & low beam headlamp
HID-D2S
Parking light
2827
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
H1-55W
H1ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H1XV XtraVision Halogen - The Brighter Light
License plate
168
Back up light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
194
Map light
DE3175
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
Old Sep 29, 2007 | 08:30 PM
  #82
finagle69's Avatar
finagle69
Originally Posted by DrJones
finagle69:
another post from me. this should answer your questions.
https://www.myg37.com/forums/showpos...&postcount=109
Old Sep 30, 2007 | 03:45 PM
  #83
DrJones's Avatar
DrJones
Thanks for the link!! Cheers!
Old Sep 30, 2007 | 09:42 PM
  #84
rmc314's Avatar
rmc314
Installed LEDs from Superbrightleds.com
just a word of caution. the light in the glove box is NOT NOT NOT the same as the rest of the bulbs... i found this out the hard way... by taking it apart.
anyway here are some crappy pics because my camera sucks, as well as my photo skills.
which lights did u buy for the rear plates? thanks
Old Oct 1, 2007 | 11:29 AM
  #85
finagle69's Avatar
finagle69
check here. i put the 4's in the license plate lights.
Old Oct 1, 2007 | 12:08 PM
  #86
]\[ /-\ ]\/['s Avatar
would the 4s or 5s fit in the side of the door?
also, did u replace the little street light in the headlight right under the fog light?
Old Oct 1, 2007 | 12:53 PM
  #87
finagle69's Avatar
finagle69
not sure if i know what you mean by "side of the door", but if you mean the courtesy light that illuminates your foot when you open the door, yes, i replaced those with 6's.
the little street light in the headlights have GOT to go. not cool to have yellow mixing with blue. that'll be next on the list, just have to make time to reach in there and pull it out to see what i need to replace it with. if anyone knows and has a recommendation, i'm all ears. it needs to be replaced with something high quality due to the heat buildup in the headlamp housing.
Old Oct 1, 2007 | 01:24 PM
  #88
yea...that's the one i meant..the courtesy lights...thanks!
and the little street light in the headlight is also a 194/168 bulb...i was also thinking bout changing that H1 foglight to HIDs but dunno if the heat would be too much for the headlight housing
Old Oct 1, 2007 | 02:18 PM
  #89
finagle69's Avatar
finagle69
cool, i didn't know the city light was the same... i happen to have a couple of spares.
Old Oct 1, 2007 | 05:15 PM
  #90
Ahujadaddy's Avatar
Ahujadaddy
yea man, i was tellin u in another thread its the same as the ones u used in the license plate light.
I hear u hafta take intake box off to install... good time to install the lights then wd be when ur changing over to fujita intakes hehhe, which u already have done
I'm just trying to decide which color bulb will most closely match the HID headlight.
