Nor Cal G Nor Cal G - operating for the Northern California G35's and surrounding areas.
Help! Bumper removal/installation.
Old Aug 17, 2005 | 07:58 PM
vodkarocket's Avatar
vodkarocket
My car was in a hit & run last week, and my body shop was kind enough to order me a brand new bumper at 1/2 of MSRP, and squeeze me into their busy week for prep and paint of this new bumper. Since I can't afford any down time with my car, I will have to install the bumper myself one of these days after work and was hoping to get some help.
I was wondering if anyone local has ever replaced a G35 rear bumper, or has some skill in regards to this kind of job.
I have all the tools that would be necessary, as well as a bunch of beers to keep you hydrated.
Old Aug 18, 2005 | 03:01 AM
skeleton_cru's Avatar
skeleton_cru
Sorry, I've only done the front bumper.
Old Aug 18, 2005 | 02:07 PM
NismoV35's Avatar
NismoV35
Boris,
When will you have the Bumper Back from the Body shop? I might be out in Fremont during the Week. I've done the front on our cars. I've Removed many Bumpers on Hondas. I also have the Shop manuel just in case, Let Me know, David
Old Aug 18, 2005 | 02:58 PM
inTgr8r's Avatar
inTgr8r
Proud member of the COFC
It's really not to hard to do.
I've done it a couple of times.
Most of it is obvious. (from memory so may not be exact)
- pop clips on the trunk openning trim, then lift off
- remove tail lights, nuts on the inside
- plastic valance trim right behind rear wheel, bolt & spring tab
- a couple of bolts on the lower valance
& then.....
- 3 bolts on each side from inside the trunk; blue circles in pic
- 2 clips in green circles, gently pry up
Hope this helps...
Good luck with it
Attached Thumbnails Help! Bumper removal/installation.-bumper.jpg
Old Aug 18, 2005 | 03:05 PM
vodkarocket
& then.....
Hope this helps...
Good luck with it
Wow, thanks!
You make it look so easy!
I have no problems getting messy in the engine bay, or working with suspension/brakes, but am hesitant to work with the body panels.
Old Aug 18, 2005 | 03:06 PM
vodkarocket
Originally Posted by NismoV35
Boris,
Thanks for the offer David- I get it back either Saturday or Monday.
Old Aug 22, 2005 | 11:00 AM
inTgr8r's Avatar
inTgr8r
Wow, thanks!
No problem..
If you run into a snag let me know.
Old Aug 22, 2005 | 11:07 AM
inTgr8r's Avatar
inTgr8r
Just thought...
Here's a better detail of the clips in the middle.
They're the trickiest to deal with.
Attached Thumbnails Help! Bumper removal/installation.-bumper2.jpg
Old Aug 22, 2005 | 08:29 PM
vodkarocket
Thanks again for the detailed images.
I will attempt this tonight.
Do you have a rough idea of the time it takes to take off/reinstall a bumper?
Old Aug 25, 2005 | 04:47 AM
NismoV35's Avatar
NismoV35
Boris Did You Get Your Bumper On?
Old Aug 25, 2005 | 12:29 PM
vodkarocket
Yeah, thanks.
My body shop was kind enough to do this for free.
2K1 6T8
Oct 6, 2015 07:40 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
botlfed98
Sep 29, 2015 12:07 PM
Allboutcali
Sep 26, 2015 03:43 PM
