G37x coupe lowering advice
Old Jun 16, 2025 | 12:59 AM
charlie3.7's Avatar
charlie3.7
New to the lowering scene. I recently bought bc coil overs and need some advice. What do I need to have a somewhat reliable lowered car. Like camber kits and other things. Thanks !
Old Jul 9, 2025 | 07:09 AM
Cortez's Avatar
Cortez
Hey, welcome to the G scene and congrats on the BC coilovers. Since you’re new to lowering and have a G37x (AWD), here’s a straightforward breakdown of what you’ll need to keep your setup reliable and aligned:
1. Rear Camber Arms
Lowering will add negative camber, especially in the rear. Adjustable camber arms let you correct that and avoid uneven tire wear.
2. Rear Toe Arms
Lowering affects toe alignment too, which can ruin tires quickly. Adjustable toe arms help bring that back into spec.
3. Front Upper Control Arms (Optional)
Not 100% required for mild drops, but they do give you more camber adjustability up front, which helps if you’re looking for a precise alignment or running aggressive wheels.
4. Full Alignment After Install
Once everything’s installed, make sure to get a full 4-wheel alignment. The AWD system is sensitive to bad alignment, and this helps preserve tire life and handling.
5. Be Mindful of Axle Angles (AWD-specific)
Don’t slam the front too low. The CV axles can wear out quickly if the angle is too sharp. A safe drop for AWD is usually 1.0–1.5” front and 1.5–2.0” rear.
6. Fender Clearance
If you’re running wider wheels or lower offset, you might rub. Rolling your fenders can help prevent that.
7. Watch Tire Wear
After the drop, monitor your tires regularly to catch any uneven wear early.
Old Jul 9, 2025 | 02:17 PM
KC240SR's Avatar
KC240SR
Originally Posted by Cortez
2. Rear Toe Arms
Quick addendum to this:
Rear toe arms are only usable if the coilovers you purchased are a true coilover rear (not divorced spring/strut like OEM), as they replace the spring buckets. If you have coilovers which are in the OEM configuration, you can use aftermarket toe bolts for a bit of extra adjustment.
Jsemi524g37x
May 1, 2017 12:31 PM
rchivers
Jun 3, 2014 01:12 PM
jaymillG37
Dec 26, 2010 07:35 PM
