Beginner-needs HELP G37 S (2013)
Old May 16, 2023 | 04:10 PM
owecin's Avatar
owecin
My G37 S mechanic advised to go to the dealer to get correction for the following message on: I am due for smog check , and has 93K miles on it
Pending Fault - Mass or Volume Air flow circuit range performance problem. He also mentioned about a mass sensor needs to be changed and computer programmed?
Kindly advise what does it take to correct so that I will not go to the dealer not knowing anything and get blindsided by the bill to repair. THANK YOU.
These are the services - I had recently
-I just had the sun roof drain tubes replaced , and the computer replaced due to water intrusion. (car was dead and has to be done) and the rest was suggested
- Transmission serviced
-power steering oil changed
-Engine air filter changed
-brake fluid changed
-Intake DeCarb (Cleaned Intake system)
-spark plugs
Old May 20, 2023 | 08:02 PM
zoe infinity's Avatar
zoe infinity
Welcome to the forum
KingCuevas
Oct 10, 2023 01:45 PM
Gabe Cady
Apr 14, 2022 09:20 PM
GoFightNguyen
Feb 27, 2022 02:45 PM
Mauriciog_15
Dec 12, 2017 11:30 PM
juicebox24
Nov 11, 2016 07:27 PM
