Best upgrades at the start?
Old Aug 14, 2023 | 10:08 AM
  #31
socketz67's Avatar
socketz67
Community Builder
Originally Posted by hexotic
Transmission, the dealership will refuse to do. They call it lifetime fluid. Basically there are clutch packs inside this transmission that wear down and clutch material is suspended in trans fluid. Doing a flush beyond 70k gets rid of that clutch material – not recommended as the transmission may start slipping. You can do a drain and fill, but not a complete flush. If the car is above 100k, don't touch the fluid, leave it as is.
@hexotic Have you experienced this first hand? Dealers telling you no? I have brought this up to my local service writing group that I have used for years (3 different ones), and none of them advise against drain and fills. Only one advised against a "fluid exchange" (replaces around 10 quarts of fluid through a vacuum process). I just had the fluid drained and filled in my son's Ford Ranger at 200K miles (prior to that, at around 170K miles). No issues. I can't imagine JATCO transmissions behave a whole lot different as far as wear and clutch material selection than Ford. I had my transmission fluid exchanged at 43K and the improvement was noticeable. Had planned to do it again at 73K then again when I go over 100K if I still own the car.
​​​​​Maybe ​@BULL (or some of the others that are mechanics at Nissan/Infiniti) has some thoughts on this topic as his knowledge of the platform seems to go pretty deep.
Old Nov 7, 2023 | 05:26 PM
  #32
lektrix's Avatar
lektrix
Originally Posted by brezzsent
I'd get the Sport rear sway bar really makes the handling on the awd more neutral as the awd tends to understeer a bit. The sway bar makes the car feel more planted with less body roll.
Had my 2012 G37X sedan for 5 years and wish I saw this thread earlier...... which rear sway bar do you guys recommend? product link please, anything from Amazon?
Old Nov 7, 2023 | 05:33 PM
  #33
Any of the name brands...they're all good enough. Hotchkis, Eibach, Whiteline, Stillen, etc.
Black Friday is coming up.
Old Feb 3, 2024 | 09:39 PM
  #34
absurd37's Avatar
absurd37
2009 g37
I did it on mine at 74k miles, runs perfect. It's hard to give a straight answer since it may differ a bit from car to car and how much it has been abused or not. If you're in the 70-90k mile range, it's a good time to do it because doing it beyond that could have negative effects. That's about all I can say and you have to make the decision based on your situation.
P.S. the AT in the G does not like hard launches from stand still. Roll pulls are fine, but from a dig, would not recommend doing it too often. I'm on my second transmission, just saying lol
I have a 2009 G37 93kmiles, it’s shifting a little slow or hard I would say, is a transmsission drain and fill the move right now? I’m also having terrible mpg, on odometer it says 11.4
Old Feb 4, 2024 | 09:56 AM
  #35
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
That's probably pushing it and would be saver to keep it as is.
Although if you have the Q1 2009 car with the 5 speed instead of 7 speed, it may have a dipstick where you can check the state of your fluid. Or add a dipstick to the 7 AT, it has the provisions for it, they just put a plug in the hole where it attaches.
Often the issue is in the valve body and changing the fluid wont solve the issues.
Old Feb 4, 2024 | 03:27 PM
  #36
absurd37's Avatar
absurd37
Thanks for replying bro, so you’re saying trans fluid drain and fill won’t be good for anything? I researched online, trans drain and fill helps benefits with shifting smoother and better mpg. Im about to do a MAF sensor and intake clean. What do you think?
Old Feb 4, 2024 | 04:06 PM
  #37
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
So the way my master tech friend described it is the transmission in our car uses little clutches and that material wears down over time and is deposited into the fluid. As long as this material is in the fluid, the transmission clutches don't really slip, but if you drain and fill at this high mileage, you may lose too much of these particles. This is generally why Nissan says its life time fluid. You are most likely going to be fine if you do it, but in rare cases it does more harm than good.
I'm not a professional by any means, so wouldn't hurt to run this by someone that works on these on a daily basis, but this it the answer I got when asking these questions.
As for the maf sensor and intake clean, totally cool to do, I do mine every year along with the throttle bodies. If messing with the throttle bodies, make sure to do the proper post cleaning procedures. Acceleration pedal release position relearn, Throttle valve closed position relearn, Idle air volume relearn. Look up Motorvate DIY on youtube, I think episode 27 is where he does a nice guide on how to do these.
Old Feb 5, 2024 | 07:02 AM
  #38
camopaint0707's Avatar
camopaint0707
Proper 200tw tires should be the first thing anyone does.
Old Sep 25, 2024 | 05:44 AM
  #39
Jchag28's Avatar
Jchag28
2012 g37x awd
I have a 2012 g37x awd sport ,
mods I have
-hfc fast intentions
-z1 motorsports cat back exhaust touring
- afe throttlebody spacers aluminum
- z1 motorsports ported intake plenum (upper & lower)
-z1 motorsports 2.5 inch long tube cold air intakes
-no tune yet
- stock suspension still
Hey everyone what should be my next mods ? Staying n/a for a while to save up but I still want to upgrade to get the most out of my engine, lmk what I should do next. probably keep going performance wise
Old Sep 25, 2024 | 07:09 AM
  #40
mods I have
-no tune yet
That mod list... time for a tune.
Old Sep 28, 2024 | 08:41 AM
  #41
hexotic's Avatar
hexotic
DIY Cheapskate/Mod
mods I have
-no tune yet
Tune would be great to take advantage of all those mods, but don't forget you also need to put the power down reliably. Tires, sway bars and other suspension components will go a long way. If I were to build my car again, I would do all the suspension first instead of sound and power mods. Getting the sway bars was a real eye opener.
Old Dec 3, 2025 | 08:31 PM
  #42
DeafJam92's Avatar
DeafJam92
Originally Posted by PhatherPhish
Before doing anything to add power I recommend doing some supporting mods. The engines in these cars tend to run hot. Whether your G is your daily driver or weekend toy I highly recommend installing a thermostatic engine oil cooler and an auxiliary transmission cooler in-line with the one built into the radiator. Z1, Stillen, and Mishimoto make oil cooler kits. Stillen makes a transmission cooler kit. Building your own kit will probably be cheaper. But, this isn’t an area I would personally go cheap on.
I’d take a look at the diff bushing to see if it needs to be replaced. The stock one is fluid filled and eventually will probably leak leading to the rear diff flopping around. If you see a trail of fluid or there are visible cracks in the rubber, I’d replace it. Z1, whiteline, and a few others sell solid urethane bushing kits. New diff bushings in combo with subframe bushing collars or solid subframe bushings will help tighten up the rear end and give you marginally better acceleration off the line. It’s also one of the more cost efficient mods you can do.
Look into swapping out the open rear diff for an LSD. RWD sport models came stock with an LSD so swapping one into your AWD shouldn’t be too much of an issue. I’m not sure what the details of the swap are but I know there are several people on this forum that have done it.
Like Rochester suggested sway bars are a very good upgrade. Eibach, Hotchkis, and Z1 are probably going to be the top picks.
late to the party, but the rwd sport model have a viscous limited slip differential, that are prone to overheating, z1 offers aftermarket lsd you can swap out but requires a full diff swap
Old Dec 3, 2025 | 10:24 PM
  #43
socketz67's Avatar
socketz67
Community Builder
Unfortunately, on the 7AT swapping the pumpkin with one from a 6MT or crossover year G35/7 Sport Model is not straightforward.
I have never heard that the sport model VLSD overheats, only that the vicious fluid inside of the diff eventually loses its functionality. My car is 12 years old and it still works fine.
Old Dec 3, 2025 | 10:44 PM
  #44
DeafJam92's Avatar
DeafJam92
depends what your throwing at it, , anything in the 400-450 + ft lbs of torque tends to get it there
  #45
DeafJam92's Avatar
DeafJam92
if you keep it under there then yes the vlsd will do ya fine
