P0300 - please help
Old Oct 12, 2021 | 04:51 PM
Mitch355277's Avatar
Mitch355277
P0300 - please help
Please help!! i have a 2010 g37s with 115k on it. im having a p0300 issue cylinder 1,3,5 seem to be misfiring the most. I have changed the battery spark plugs all 02 sensors. I have stillen intakes fast intention test pipes and invidia catback exahust below i have shared the bluedriver info if anyone can please help me with this issue.
Old Oct 13, 2021 | 12:22 PM
SonicVQ's Avatar
SonicVQ
How long have you had this issue and how long has the test pipes been on?
Old Oct 13, 2021 | 12:26 PM
Mitch355277
I’ve been having the issue for about 4 months now car just got test pipes last month. I understand the car will need to be tuned. But for car to be tuned the misfire need to be addressed.
Old Oct 13, 2021 | 12:47 PM
SonicVQ's Avatar
SonicVQ
Understood.
Using the live data section of the BlueDriver, look at the short term and long term fuel trims for each bank, WHILE the engine is at a hot idle.
What are they?
Old Oct 13, 2021 | 03:14 PM
Mitch355277
Originally Posted by SonicVQ
Understood.
What are they?
long term bank 1 5.5%
short term bank 1 -5.5%
short term bank 2 4.7%
long term bank 2 7.0%
o2 bank 1 .280v
and 02 bank 2 says n/a
Old Oct 14, 2021 | 05:18 PM
SonicVQ's Avatar
SonicVQ
Weird... your mis-fires are on bank 1, but your bank 2 fuel trims are a little high and you don't have a reported voltage for B2S2.
Old Oct 14, 2021 | 06:07 PM
Mitch355277
i don’t want to keep throwing money at it because I don’t know. Could it be the ignition coils? It’s werid to me because it’s 1,3,5 so I thought injectors.
Old Nov 25, 2021 | 04:00 PM
BigSpoon's Avatar
BigSpoon
Subscribed to follow for any resolution. I too am being told I have a Cylinder 3 misfire by an Infiniti dealer currently. They've swapped the coil packs and plugs and it's still misfiring and they told me they think it could be the pigtail/harness connector from the ignition coil pack to the main engine wiring harness maybe. Sigh.
Did you get it figured out?
Old Dec 3, 2021 | 12:29 PM
Mitch355277
no I am still having this issue. 1,3,5 seem to be having the most misfires.
Old Dec 3, 2021 | 03:12 PM
BULL's Avatar
BULL
Moderador
It is possible that the scanner is mixing the PID. I've had some issues in the past where the scan tool mixed my TPMS sensors as well as one of my AFRs.
OP you should disconnect the bank 1 02 sensor and see if reading goes blank. If it does then try swapping the the sensor over or see if Bank 2 connector will reach bank 1 sensor and see if bank 2 starts reading.
If it does start with the obvious sensor on bank 2 and go from there.
boweld
Sep 24, 2018 06:40 PM
jose_aoc
14
Jul 27, 2018 03:20 PM
SS2006
Mar 22, 2016 09:50 PM
zzww1251
Jan 19, 2015 11:24 AM
G+36+1=
13
Apr 25, 2012 12:50 PM
