2 weeks of owning a g37x 2011 168k HELP
Old Jul 31, 2019 | 09:44 PM
Mts Roman's Avatar
Mts Roman
So when I put the car in drive when I’m on idle (foot on break ) I hear a ticking noise , also from my transfer case seems to be something leaking and you can see getting drags due to momentum. Had for about 2 weeks tbh, came bone stock, (added window visors, drilled and slotted brakes, license plate relocation and front lip, LED interior and exterior ) best recommendation to making the car louder , with stock exhaust. And intakes please and thanks
Old Aug 1, 2019 | 12:11 AM
slartibartfast's Avatar
slartibartfast
I don't understand what you mean by drag.
As for intake and exhaust, look at the Tech/Intake and Exhaust forum, the Review/Intake and Exhaust forum, Tech/Build forum and the Vendor forum.
Old Aug 13, 2019 | 11:25 PM
Nick2011g37x's Avatar
Nick2011g37x
Ticking noise
This is the first "problem" I had with mine. I was very concerned when it started happening but after hours of searching I found it to be a broken push pin that holds the windshield washer reservoir in place. Pop a new one in and idle happy once more. If that's not it, take a look at heat shielding, specifically the heat shielding around the cat. I'll hope it's the first solution though!
djgoody12
Dec 2, 2015 03:54 AM
G+36+1=
Jan 25, 2012 12:25 PM
StevieGConnor
Sep 24, 2008 01:35 AM
