Recently just joined this forum not knowing it existed while i had my 2009 infiniti g37S for over a year. I've done a few mods including a invidia catback exhaust with Berk Hfc's and weapon R short ram intakes. I've recently bought a set of cosmis XT-006r's 18x9.5 with a +10mm Offset and was looking to see if they would be able to fit my g37. I test fitted them out in the pictures below, they had 20mm spacers all around but i haven't fitted them without it yet. Would they be able to fit G37s brakes without the spacers on? and would i need to modify anything else with the fenders?
Welcome Jose, hopefully the wheels will clear without spacing as they're already way aggressive. you may need extra camber to get the tires safely tucking into the fenders but ???.
It looks like you've already test fit them, but if not, cover your calipers w/ blue painters tape so you won't nick them up trying to determine clearance. You will want at least 2-3mm clearance when fully tightened down. Probably have to keep your tires more on the narrow side too, like a 255/45/18.
G'luck,
Brad
