Tire Questions
Old Aug 24, 2017 | 02:04 AM
haanguu's Avatar
haanguu
Tire Questions
Hello Guys,
I'm thinking about buying these set of tires.
These are the specs.
Front: 225/35/19
Back: 255/30/19
I was wondering will these be fine as a setup?
Will it feel different from OEM setup? which are
Front: 225/45/19
Back: 245/40/19
any input would be great!
Thanks guys.
Old Aug 24, 2017 | 08:36 AM
Originally Posted by haanguu
Hello Guys,
Front: 225/35/19
Back: 255/30/19
Front: 225/45/19
Back: 245/40/19
Thanks guys.
Those are much shorter than OEM, over 7% in fact, I wouldn't recommend it. Try to stay under 3%, and if you have AWD you need your front to rear diameter difference to be under 1%.
Also those short sidewalls will make for a very firm/harsh ride and you won't like it when you get to rough roads for sure.
Use this calculator when trying new setups
Old Aug 24, 2017 | 06:41 PM
saywat?'s Avatar
saywat?
are u lowered? doing those sizes will increase ur wheel gap and look retarded if ur not lowered.
Old Aug 28, 2017 | 02:19 PM
kiseliok's Avatar
kiseliok
G37 Community Team
^ lol! That's a good way to put it without sugarcoating..
