Need 20x10 tires help
Old Apr 18, 2017 | 09:42 PM
Chillpyl's Avatar
Chillpyl
Hi all, just started to mod the wife's car (13 g37x sedan), i recently bought 20x10 +38 wheels, I was wondering what size tires i can put on them to avoid rubbing since i plan to lower the car on coils down the road? Any advice would be appreciated
Old Apr 18, 2017 | 09:58 PM
You're going to have to run a slightly stretched 255/35/20, should tuck inside the fender ok with a bit more camber, but the actual wheels will extend outside the fender edges about 8-10mm. A 255 on a 10" width is a common mount so you shouldn't have any problems running them. A 245/35/20 will give you 5mm more wiggle room at the fender edge but it exceeds manufacturers recommendations for that width tire on that width wheel, so if you do that do so at your own risk.
Old Apr 18, 2017 | 10:09 PM
Monsoon520's Avatar
Monsoon520
I'm running a 255/35/20 on a 10.5 inch wheel
Godspeed springs
Fitment works great for me no rubbing issues at all
Old Apr 18, 2017 | 10:59 PM
Chillpyl's Avatar
Chillpyl
Awesome thanks all
