Seat Position Help
Old Jan 19, 2017 | 01:51 PM
JustROLLIN's Avatar
JustROLLIN
Seat Position Help
Hey all,
New owner and new to this forum. I have a 2013 G37X AT w/o Nav. Anyway, I am having an issue where every time I get back in the car, I need to move my seat back to the preferred position. I am a taller guy, so I like it pushed all the way back. But, each time, the seat is slid up from the spot I left it.
Question is, how do I keep the car from moving the seat back another spot. I went through the steps in the owner's manual, but apparently did something wrong. I set my spot with the seat, wheel, and mirrors, and then pressed both set and the #1 button at the same time until they lit up. Not sure why it did not stick.
I feel like a moron, but would certainly love some help. Thanks in advance.
Old Jan 19, 2017 | 03:10 PM
Welcome to the site, you need to press just the SET button until both #1 & #2 light up, you then select one of the two buttons for your setting and hold for a second, the number you pushed will light up for about 5 seconds. Here's the procedure link~
https://www.manualslib.com/manual/51...n.html?page=39
Old Jan 19, 2017 | 03:32 PM
JustROLLIN's Avatar
JustROLLIN
Great, thanks for the help! I will give this a run and report back. Take care.
Old Jan 19, 2017 | 11:57 PM
JustROLLIN's Avatar
JustROLLIN
Worked perfectly! Thank you. It was a small thing, but nagging.
Old Jan 20, 2017 | 01:49 AM
JSolo's Avatar
JSolo
Just say no!!!!!
There's a convenience setting that links a remote to a desired position (#1 or #2). Probably best to just disable that altogether if you're the only driver. It's somewhere in the settings menu under convenience features.
Old Jan 20, 2017 | 10:14 AM
JustROLLIN's Avatar
JustROLLIN
Hey, thanks for mentioning this in case anyone else has issues. I did in fact disable that function early in the going. And yes, its in the settings menu under convenience.
