Tires size
Tires size
Front 235/35/19
Rear 265/30/19 or 275/30/19
Juss wondering if I get this tires would it affect my speed sensor?
Planning to buy rims and dropping it wit eibach lowering spring thanks
The only thing holding my back is hat would it affect the speed sensor bcoz I want to drop it too with the eibach lowering spring yea I was planning that spec too if u had that on ur car can I see a pic thanks. Would I need to put a camber kit if I drop it thanks
Check out Online Wheel and Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit it's a very helpful tire/wheel guide that tells you the difference between your current and new wheels.
With eibach springs you may be able to get away without needing a camber kit. I'm on 245/40/19 all around with coilovers dropped about 2 inches. -1.5 camber front -3 rear
Infiniti G37 Picture by the93owner | 5101481 | MyG37
I would probably bet that everyone goes with this setup when they're first switching to aftermarket wheels (staggered of course). Search around and you'll find plenty with a mix of different suspension set ups.
