Vossen cv3 fitment
Old May 29, 2015 | 10:53 PM
Fritz's Avatar
Fritz
Vossen cv3 fitment
Hey fellas quick question for you all. Still learning when it comes to Fitment especially on the infinitis. I found a good deal on cv3's that I'm looking to get! Specs are:
20x9.5 +20 front and 20x10.5 +5 rear
Going on a lowered g37 sport. To me fronts should be good but rears I'm worried might be too aggressive. I will be replacing tires on them so I'll be able to get the right size to hopefully fit. However will I be able to get away without rolling fenders? Also I believe I should be fine with the sport brakes with this offset correct?
Thank you for the help guys I appreciate it!
Old May 29, 2015 | 11:02 PM
If it was in the +20s that would work w/ a stretched tire, but a +5 will need stretch, camber and pulled fenders. I think I'd keep looking unless you're committed to do all the work req'd. And I assume you have the coupe, the sedan would be an even bigger no-go.
Old May 29, 2015 | 11:12 PM
Fritz's Avatar
Fritz
Thank you for your responses. I forgot to mention it is a coupe. It's a bummer that the rears are so aggressive on the set I found, I definitely don't want to have the tires stretched never mind rolling the fenders, may have to look at different wheels...
Old Jun 2, 2015 | 06:53 PM
gtmonsters's Avatar
gtmonsters
MYG37 Sponsor,also Batman
it would be pretty though...
Dillybar12
Nov 1, 2015 07:23 PM
stm37s
The M - Spot
14
Oct 23, 2015 01:56 AM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
John B
Sep 27, 2015 11:41 PM
pal51961
Sep 27, 2015 08:38 PM
