What would you do?
What would you do?
Okay so I have 08 gray G37S coupe. With nothing done but 20% tints all around... I have the opportunity to either get a exhaust system or rims, and I am completely torn between the two, so I would like others opinions on what you guys would do.
What I have in mind for the exhaust is the ARK GRiP Exhaust because of the sound and even the look from the back end. (Open to exhaust suggestions)
As for rims, I'm set on the "Stance five spoke SC-5ive machined rims".
So basically id just like to know what you guys think of both products and which one you would get if you only could have one. I'm completely torn between them right now.
Okay so I have 08 gray G37S coupe. With nothing done but 20% tints all around... I have the opportunity to either get a exhaust system or rims, and I am completely torn between the two, so I would like others opinions on what you guys would do. What I have in mind for the exhaust is the ARK GRiP Exhaust because of the sound and even the look from the back end. (Open to exhaust suggestions) As for rims, I'm set on the "Stance five spoke SC-5ive machined rims". So basically id just like to know what you guys think of both products and which one you would get if you only could have one. I'm completely torn between them right now.
I like your style though. Welcome to the forum.
Drop first for sure. If you don't want to go all out, just get the swift springs and spc camber kits and move on. You should be able to get dropped and aligned for not to much over 1K parts plus labor w/ this setup.
