1st time at the track!
do u guys flat foot shift ur g37s?! also i tried 2 do a stand still but when i dropped the clutch and dove onto the break it killed the engine is that normal or was i just not revving it high enough
Nissan/Infiniti have a brake over ride system.
When throttle & brake are hit at the same time, result is no power.
When you launch, just hold the clutch to the friction point & a 2k launch should keep you from roasting your clutch or your tires.
Btw, car did you run against?
Good run
Pretty good run for your first time out. Your launch isnt great but the real story is the fox body's launch. a fox body that hooks up can hit 1.7s 60ft. Normal is like 2 flat. You have to smile knowing that it killed him a little inside to see your tail lights pulling away haha
inspector94
Sep 8, 2015 12:57 PM
KZK
Canada
Sep 2, 2015 05:30 AM
