New to the club
Old Mar 2, 2012 | 10:51 AM
GripSome30's Avatar
GripSome30
New to the club
I'm new to this site but I have been checking this site out ever since I owned my G. Are there any member in the Atlanta Ga area. Just wondering?
Old Mar 2, 2012 | 11:00 AM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
Welcome to the forum, I'm sure there are members from ATL
Old Mar 2, 2012 | 12:59 PM
GripSome30's Avatar
GripSome30
Thanks, never realized how many people were actully on this forum.
Old Mar 2, 2012 | 01:33 PM
Welcome to the forum. There's plenty of members here from your area. Cereal2k lives there and is very active, I'm sure he'll probably pop into this thread soon. Check the Southeast regional forum to see what's going on there.
Old Mar 2, 2012 | 02:16 PM
GripSome30's Avatar
GripSome30
Yea i checked the southeast Thread they were talking about IA in GA i waiting to see when the meet is and where its loacted. i don't have any friends here that are in the scene, coming out of Miami to here is a big difference.
Old Mar 2, 2012 | 02:23 PM
D_Rek's Avatar
D_Rek
Mos def there are ppl from GA on here.
Welcome to the G fam.
Old Mar 5, 2012 | 11:26 AM
baconbaconbacon's Avatar
baconbaconbacon
Welcome to forum. I am out in Atlanta as well. Just picked up my '12 G37S Coupe on February 7 and installed my K&N Typhoon on it last Monday. Loving it :-)
Old Mar 7, 2012 | 03:30 PM
GripSome30's Avatar
GripSome30
how much of a difference did the typhoon make? i was going to buy it but i did rims and tires instead. now i am whiching i would have went ahead and got the typhoon and my header and exhaust done instead.
Old Mar 7, 2012 | 05:10 PM
Diego@Vossen's Avatar
Diego@Vossen
Welcome aboard! There are quite a few G25/35/G37 owners in Atlanta and quite a few with Vossen Wheels!
Old Mar 7, 2012 | 11:31 PM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
Welcome to the forum!
We have some monthly meets coming up and I'll be sure to remember to update the south east section.
We have a local group using facebook for quick communication if you do the facebook thing.
Old Mar 12, 2012 | 09:50 AM
baconbaconbacon
It sounds great! As for performance, it definitely has some extra pull based on the butt dyno, but it's all north of 3500 rpm. I did flash the ECU with the pedal mash, timing method and it seemed to help some of the perceived "bog". If you are doing intake, headers and exhaust you are probably going to get a proper tune anyway, so that should be a non issue.
The install of the K&N typhoon is a snap and the fit and finish is great. The one exception is the passenger side crankcase breather vent hose that needs to be trimmed down to fit the G37 instead of the 370z.
You may see comments on the Typhoon being a "hot" air intake because the heat shield and shorter tubes sit in the engine bay in the stock position, rather than being placed in the front air dam like Stillen, Takeda and others. The reality is there are direct air paths through the grill that lead right to the K&N heat shield box. The performance is great and you would be hard pressed to find better bang for the buck. I got mine off Amazon for $271.98 shipped.
Old Mar 13, 2012 | 07:01 PM
GripSome30's Avatar
GripSome30
Yea i was going for the Cold air but with the rain and lack of proper water draining systems in GA i might not. i don't want water in my motor i already had the motor replaced once already. When ever i get it all done i will dyno it and see what the numbers say. Numbers never lie!!
Old Mar 19, 2012 | 10:41 AM
baconbaconbacon
You won't have a problem at with water, especially with the K&N, unless you are forging low water crossings! To my knowledge, even the guys with the Stillen Gen 3 don't really have any problems with rain and standing water.
The Typhoon system replaces the stock boxes and the tubes and filter with heat shield terminate in the same location as stock. There are ports from the grill into the stock air boxes and when you replace them, you just get more air flow directly into the conical K&N filter. Someone would have to put a firehouse to the front end to get enough water in there to have any kind of a negative impact.
Don't worry about water at all...any of the reputable aftermarket intakes should make you happy.
Old Mar 20, 2012 | 01:54 AM
cereal2k's Avatar
cereal2k
For those who are local, there is a dyno day Saturday at Z1 Motorsports and a Mountain Run on Sunday with the local 370z guys.
SouthEast - MyG37
steven92
NorthEast
Dec 9, 2015 01:24 AM
gdaelemans
Sep 13, 2015 09:36 PM
m3clubracer
Sep 13, 2015 09:01 AM
