Alignment question from a nOOb
Hi All,
I need to bring in my G for a re-alignment. I have stock wheels/tires (for now), am I safe bringing my baby to an Express Tire or Discount Tire to do the job?
Thanks in advance.
Thanks in advance.
There's a distinction between being in spec and being at optimal. The latter is a subset of the specification, optimized for better handling, cornering.
The kids at sears/discount tire will adjust it such that the computer shows green. Whether or not they understand how these numbers translate into practical application is a different matter.
Do realize, that from the factory, the front end is only adjustable for toe. You need different suspension components to be able to adjust caster/camber. On some cars you can loosen the struts to get a little bit more camber adjustment without going with full blown camber kit. I'm not sure if the suspension on the G falls into this category or not.
I believe the rear is toe only too, without additional adjustable arms.
You say you need to bring it in for a re-alignment. What was wrong with the first alignment? Was the car in an accident, does it track funny or pull to one side?
If the goal is just a matter of obtaining current alignment specs, then it shouldn't be much of a brainer to get those from a cookie cutter place. Try to use one that uses the new prism heads. They are more easily compensated and less error prone than the old RF/bubble level heads.
Thanks Jsolo.
My GF (don't ask me why I let her drive the G) went over a curb leaving a gas station. No body or undercarriage damage but the passenger side front tire/wheel hit pretty hard. It now pulls slightly to the right.
Front camber isn't adjustable, toe is. Rear camber and toe are adjustible. Many places besides a dealership do great alignments. Look for a local frame and front end shop, that's what they specialize in.
