Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Any 3.35 gear to 3.69 track results? TIMESLIPS!
Old Nov 20, 2021 | 09:05 PM
JME377's Avatar
JME377
Does anyone here have any time slips that shows the gains you made when swapping in a 3.69 gear from the stock 3.35. My car on has a few bolt-ons but I and looking to do this swap!
Old Apr 18, 2022 | 02:33 AM
JME377's Avatar
JME377
Has anyone done this gear yet with dragy or track timeslip results? I have my rear diff but not installed yet
Old Apr 18, 2022 | 08:42 PM
14Q60awdSPORT's Avatar
14Q60awdSPORT
Final drive swaps are very situation dependent.
To over simplify it. The % difference between FD ratios will be the same percentage increase in acceleration but only to the top of each gear. Then once you shift while you are now in a higher gear losing mechanical torque you will be slower while you otherwise could have continued in the previous gear, but then once you would have had to shift on the previous FD to the higher gear you will go back to being faster. FD change will also be the same percentage difference in the top speed of each gear and the increased rpm at any given gear. (With 10% FD higher ratio 2500 rpm at 60mph becomes 2750rpm at 60mph.
Another example say a car with a FD of 4.0 and hits rev limit in 2nd gear at 70mph in 7.5sec and does 63mph in 7sec and hits rev limiter in 3rd at 100mph in 14.5sec and does 90mph in 13.5sec.
The same car with a 4.4 FD will rev limit in 2nd at 63mph and 3rd at 90mph (10% less) however it should theoretically get to 63mph 10% faster then the 4.0FD would get to 63mph. So 63mph in 6.3sec (0.7faster) and 90mph in 12.15seconds (1.35 sec faster).
However because everytime you shift you will lose mechanical torque compared to previously not needing to shift the 4.4 is slower from 63-70 and 90-100.
now from a dig the more aggressive numerically higher FD will almost always be faster given traction not being an issue and not factoring in launching. The higher RPM you can launch without traction being an issue the benefits of the numerically higher FD decreases.
Now from a roll it will be very dependent on what speed you are starting from and also running up to. Many situations the 4.0 will be faster.
Ideally you pick a FD to limit needing to have an extra shift while getting as close to peak WHP as you cross the line if you trap 100mph a FD with limiter at 103-105mph would be ideal, if traction isn't an issue then this would be an aggressive enough FD to have it be 4th. If you go FI and increase power you’d want a numerically lower FD if you now can trap 115 you’d want an FD that puts limiter most likely still 4th at 118-120mph.
for track purposes it gets very complicated and very dependent on the track, serious people have multiple diffs with different FD ratios for quick swaps depending on the specific track.
for a street car decide what speeds A-B you like to run, 40-90? 60-130? Some other given speed to given speed and then you’d choose the FD best suited to that specific speed range.
Old Apr 19, 2022 | 02:59 AM
JME377's Avatar
JME377
Thanx for your reply. My main concern is just to run quicker 1/4 mile times with good traction. And coming from the Mustang world a rear gear swap like this would always achieve that goal. I was hoping to find some one who had some real world results I could see to help with my decision. And moving from a 3.35 to a 3.69 is not a bad move for the price I can get it done. (G35 diff swap) Also by running shorter rear tires(25" vs 26.7" stock) my effective gear ratio went from 3.35 to 3.60. I can tell it's quicker from that change.
Old Apr 19, 2022 | 08:25 AM
You use OEM spare wheels for the front on the track? Wow. You're really making the most out of that G for the dragstrip.
IDK about the track, but in daily driving there was a serious difference going from 3.69 to 4.08 rear gears in my 6MT. Obviously it moved the shift points down, and highway RPMs went up a bit, but man was it a worthy project.
GL
Old Apr 19, 2022 | 09:16 AM
14Q60awdSPORT
A smaller tire or shorter (numerically higher) FD will always "feel" quicker, because every gear will accelerate at the same percentage change as I described above but to a slower speed, just because it "feels" quicker does not always mean it is actually quicker depending on the circumstances.
a 3.35 to 3.69 is approx. 10% difference. it should accelerate 10% faster in every gear, but to a 10% slower speed this makes it feel to the driver 10% faster, but it isn't always the case.
with the auto trans gearing, stock tire diameter, and stock rev limiter going from a 3.35 to 3.69 will have the following results.
3.357 - 1st - 36 / 2nd - 55.6 / 3rd - 86.94 / 4th -125.82
3.692 - 1st - 32.79 / 2nd - 50.56 / 3rd - 79.05 / 4th - 114.4
0-32 mph 10% faster
32-36 mph 40% slower
36-50 mph 10% faster
50-55 mph 42% slower
55-79 mph 10% faster
79-87 mph 32% slower
87-114 mph 10% faster
114-125 mph 30% slower
From a dig because you have so much mph/rpm range in 1st gear and how much the 60ft impact the 1/4th a more aggressive gear will almost always be faster especially if the resulting gear doesn't require an extra shift.
if you are NA you probably wont be trapping over 114mph so the 3.69 doesn't result in needing an extra shift. In your case specific to the 4th a 3.69 will be very beneficial. You could probably go even more aggressive assuming you have the tire to hook up and as long as it doesn't require you to shift to 5th.
Old Apr 20, 2022 | 12:45 AM
JME377's Avatar
JME377
GL
The spare 17" (17x3.5 & 18x3.5) are just as good as aftermarket skinnys but much cheaper. I get a good deal on real street tires that last and handle well for street driving. Maxxis T145/80/17 or T145/70/18. Have driven 3k miles on a pair with little wear. The diff swap is the most affordable option for me that I can do myself. Lost out on a 3.91 diff from a G Vert. I am hoping to drop about 2 tenths off my times. I will be well worth it then!
145/70/18 Maxxis Tire
OEM 17" Maxxis 145/80/17 Spare painted Factory color
Old Apr 20, 2022 | 12:57 AM
14Q60awdSPORT
I would be shocked at anything less. Probably 3-4 tenths in the quarter.
what is your current 60ft, trap/et now?
are you AT or MT?
Old Apr 20, 2022 | 01:30 AM
JME377's Avatar
JME377
are you AT or MT?
My best 60ft is a 2.04 on 19" Pilot 4S @ the track
Here are my Best Dragy results
39 degs Outside
Best 0-60 on 13.30 pass
Best pass in 70deg weather
Just recently!! Best 1/8th MPH
Old Apr 20, 2022 | 05:18 PM
Birdie's Avatar
Birdie
[QUOTE=JME377;4309947]The spare 17" (17x3.5 & 18x3.5) are just as good as aftermarket skinnys but much cheaper. I get a good deal on real street tires that last and handle well for street driving. Maxxis T145/80/17 or T145/70/18. Have driven 3k miles on a pair with little wear. The diff swap is the most affordable option for me that I can do myself. Lost out on a 3.91 diff from a G Vert. I am hoping to drop about 2 tenths off my times. I will be well worth it then!
Are you looking for a 3.6 Diff?
Old May 21, 2022 | 01:34 AM
JME377's Avatar
JME377
[QUOTE=Birdie;4309977]
No looking Have one already and just installed it. But no times as of yet
MrTLFsr
Motorsports / Track
Mar 15, 2014 04:53 PM
HamstersG
Jul 13, 2012 02:39 AM
JEBperformance
Engine/Intake/Exhaust
65
Nov 30, 2011 02:14 PM
nethole
Feb 14, 2011 08:30 PM
