Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Which Sways would you recommend?
Old Jan 7, 2017 | 12:43 AM
xmajd92's Avatar
xmajd92
Just trying to gather information and opinions on what you track guys would recommend in regards to sway bars. I have a 2011 Journey coupe.
Old Jan 7, 2017 | 01:20 PM
4DRZ's Avatar
4DRZ
I have Hotchkis and like them just fine for the track. They also include new bushings and mounts with zerk fittings so you can grease them easily as aftermarket sway bar bushings tend to squeak after time, especially if you live in a cold climate like me.
You may not have that issue as much, but I had a set of Eibach sway bars on my last car and the squeaked like crazy. I finally had to switch to waterproof grease to get them to shut up.
Old Jan 7, 2017 | 02:13 PM
Like probably most people here, I've only had the one set of sways. I have Hotchkis and I'm very happy with them for daily driving and for track days.
Old Jan 8, 2017 | 04:41 AM
ZahyMatar's Avatar
ZahyMatar
Hotchkis without a doubt, there's currently a used set in the classifieds for only $250 shipped. That's an excellent deal.
Old Jan 9, 2017 | 11:39 AM
RMB5190's Avatar
RMB5190
I'm going to go with Whiteline when the time comes. From what I hear, Subie owners like them and that was a good indicator as to their performance. You can't go wrong with Hotchkis though especially if they are going for that^
Old Jan 9, 2017 | 11:53 AM
ttv36's Avatar
ttv36
Race, repair, repeat.
I went with Eibach in the 1 front 2 rear setting because I believe that the Hotchkis sways would increase understeer since the front is stiffer than the rear.
FRONT STOCK SWAYS are 26.5mm / 416 pounds per square inch
REAR STOCK SWAYS are 24.3mm / 374 pounds per square inch
Eibach FRONT Sways 32mm Hollow
1st = 730 lbs
2nd = 900 lbs
Eibach REAR Sways 29mm Hollow
1st = 627 lbs
2nd = 741 lbs
3rd = 860 lbs
Hotchkis Front Sway Bar 35mm Hollow
1st = 205% Stiffer (852 lbs)
Rear Sway Bar 27mm Hollow
1st = 40% Stiffer (523 lbs)
2nd = 75% Stiffer (654 lbs)
3rd = 120% Stiffer (822 lbs)
Old Jan 9, 2017 | 12:37 PM
Splitter's Avatar
Splitter
um??????
Do you mean pounds per inch?
Also, 200% is 3x, so that would put the Hotchkis at 1268.8 pounds per inch (assuming that the stock measurement is correct)
Old Jan 9, 2017 | 05:55 PM
4DRZ's Avatar
4DRZ
Are the Hotchkis sway bars really hollow? The tubing must be pretty thick if they are, since they weigh a ton. The front feels like it is made out of lead!?!
Old Jan 10, 2017 | 11:20 AM
Acrylic's Avatar
Acrylic
I have Eibach and I like them. I like how the front has adjust ability and have them on the rear and front but might take off the rear and put back the oem sway bars and leave the front with eibach.
Old Jan 10, 2017 | 01:27 PM
steven92's Avatar
steven92
Question,
When you replace sway bars do you have to replace the end links as well?
Old Jan 10, 2017 | 06:39 PM
HoldmyMouse's Avatar
HoldmyMouse
Originally Posted by steven92
Question,
Not necessary but recommended.
Old Jan 10, 2017 | 11:08 PM
xmajd92's Avatar
xmajd92
Looks like eibach and hotchkis are the favorites.
Old Jan 11, 2017 | 09:34 AM
Vizard_87's Avatar
Vizard_87
I have eibach sway bars on the stiffest setting and I like them.
Old Jan 11, 2017 | 10:28 AM
xmajd92's Avatar
xmajd92
Have any of u tested out the different settings on the track?
Old Jan 11, 2017 | 08:08 PM
4doorfury's Avatar
4doorfury
Godspeed sways. Work excellent and cheap as dirt. I have had mine for probably about 8 months
