Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Went drag racing
Old Oct 28, 2012 | 09:27 PM
Sython's Avatar
Sython
Our cars were never meant for this and are not setup to be drag racers. Nice job man for a heavy coupe!
Old Oct 28, 2012 | 11:55 PM
GotAir523's Avatar
GotAir523
Originally Posted by JohnsVert
What were your times ?
my best time was with just the intake, i ran a 13.8 @ 103. 2nd time i went to the track there were minor problems i didn't know about that hindered me from launching or doing very well.
Old Oct 29, 2012 | 08:20 AM
JohnsVert's Avatar
JohnsVert
Those are great times with just an intake , I wonder what your times are now with the mods you have listed in your sig
Old Oct 30, 2012 | 12:22 AM
GotAir523's Avatar
GotAir523
haha so am i....now that its finally getting cold in orlando i plan on taking it back to the track to see soon
Old Nov 1, 2012 | 12:01 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
Are you running stock wheels JohnsVert? I took mine to the track recently. It's way above sea level though, so it's not the fastest drag track.
I am #462 and I raced my friend's tuned 370z. Just tuned that day. Both 7AT 2009 cars. 4120 lbs on my car and his significantly lighter.
This was with DS mode and the the car doing the shifting each time. Next time I will try manual mode. This was the second time I've gone and is a vast 1 sec improvement over my first time (was in the high 15s) after getting a hang of the technique to get better reaction times. So a steady 14.8. The run without the complete time seems like an aggregated time though so 14.372?
Old Nov 1, 2012 | 12:25 AM
cereal2k's Avatar
cereal2k
Oh, on both times at the track two cars broke their rear axles. 6MT 07 G35 Sedan and a 6MT 09 G37 coupe.
Old Nov 1, 2012 | 08:48 AM
JohnsVert's Avatar
JohnsVert
Yes stock 18 inch wheels, only mod I have is a full catback ark exhaust, sea level plays a Huge part in your quarter mile time and weather, etown raceway I believe is at sea level, giving it an advantage over other racetracks throughout the United States . Track prep too always plays a role in your 60ft times , better your 60ft , better your E.T will be. Your 60ft times seems too high , I have to look at my time slips but I think my 60ft were 2.1's. And that tuned 370z should be running low 13s considering the tune( I'm assuming it has mods as well to go along with the tune), but then again like you said cereal2k you were way above sea level , so your times are probably right . I'm sure if you tracked your car at etown or even atco raceway in New Jersey or any race track that's at sea level your E.T's would be way lower
Old Nov 1, 2012 | 09:24 AM
cereal2k's Avatar
cereal2k
Good tips. I'm running 20s with recently new tires also, r2c intakes and an axle back (no power addition there). The first time I ran my tires were slightly worn (with 3 deg camber not helping) so I was spinning off the line. Getting up to speed starting out is very sluggingish, but I'll see what I can improve on next year and with manual shifting. This was the Z's first time on the track and I believe he does have an exhaust + gen 3 intakes. I will try and compare with the stock 19s at some point, but the negative camber is not helping much for dragging.
Old Nov 25, 2012 | 12:32 AM
NOWAK's Avatar
NOWAK
i just ran my stock g37s sedan today 13.89 . stock!!!
Old Nov 27, 2012 | 01:27 PM
09ChiG37's Avatar
09ChiG37
not bad!!
Old Nov 27, 2012 | 08:29 PM
Atlbrav1's Avatar
Atlbrav1
Seems these cars are very consistent in stock to near stock with limited mods. I took my 2008 G35 sedan to the track a few weeks back. Best of 4 runs was a 13.75 @ 100.14. Only performance mod to my car is a TopSpeed y-back exhaust. Temp was mild - low 70's. Track was prepped very well. Nice and sticky! Left car in full auto with traction control off, holding the brake to stage and leaving the line around 2500 rpm with very little to no wheel hop. Most important thing i noticed from this past trip was reaction time is key to a good run. Best run of the night as you can see had almost a perfect light! It was fun. Hoping to go again soon with more time available to try different things.
azndoc
Mar 23, 2016 02:17 PM
Kojack
Oct 9, 2015 05:53 PM
