Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Rev matching in 6mt
Old Mar 23, 2008 | 11:50 PM
  #31
shmad's Avatar
shmad
Originally Posted by vinnys coupe
vince i think im hearing the same noise as you, but i would have liked you to start your own thread, THREAD JACKER..but its more of a like an noise as if u can hear your clutch like open when pushing down correct? i hear it sometimes not all the time i think i hear it when im going really slow and shifting...
back to topic.. wouldent letting off the throttle loose power when shifting?
i only got this noise when i first started driving the G. i only noticed it if i didnt give the car enough gas when getting off the clutch, so the revs dropped too much. but the car stopped making that noise after i got used to the clutch after a couple days
Old Mar 23, 2008 | 11:51 PM
  #32
shmad's Avatar
shmad
Originally Posted by bnguyen85
You have to double clutch back into first gear if you are going to fast. i have my car for almost 3 weeks and i have 1300 miles.
unless ur racing, its best not to go back into first. if ur rolling, 2nd gear should have enough power for u
Old Mar 23, 2008 | 11:59 PM
  #33
bnguyen85's Avatar
bnguyen85
that is true. our cars have such a close gear ratio that it is ridiculous that we are able to drive as low as 33mph in 6th gear. I used to drive a truck with a 5 speed and the lowest I can go in 5th gear is 45mph. Even the mustang I drove 5th gear's lowest speed was 50mph. The good thing about our close ratio is it is great for the track and gear selection for perfect power selections.
Old Mar 24, 2008 | 12:00 AM
  #34
vinnys coupe's Avatar
vinnys coupe
i had mine since last month 15th, right around 1k miles...but the pointless driving has to come to an end..
Old Mar 24, 2008 | 12:21 AM
  #35
bnguyen85's Avatar
bnguyen85
Pointless? Do you all even drive your cars. I drive mine everyday to work about 30 miles a day.
Old Mar 24, 2008 | 12:25 AM
  #36
shmad's Avatar
shmad
living in NYC right now...nothing is more than 10 miles away
Old Mar 24, 2008 | 12:41 AM
  #37
bnguyen85's Avatar
bnguyen85
take a road trip, go for a cruise. Its a great car don't waste it. Did you all read the thread about the twin turbo mod. Only 8psi and it is pushing over 560 rwh. This car is wicked with GREAT potential
Old Mar 24, 2008 | 12:46 AM
  #38
chasemyaccord's Avatar
chasemyaccord
Geez, I've had my car for 4 months and I have 2800 miles
Anyway, if you want a smooth 1st->2nd shift, just hold down the clutch a little longer than your other shifts. The RPM's don't fall as quickly as they do in the other gears. Pay attention to your RPM's and make mental notes of how your car reacts under different circumstances. I figured it out eventually, I'm sure you will too.
On a brighter note, I think I've finally gotten the hang of heel-and-toeing! woo hoo!
Old Mar 24, 2008 | 01:21 PM
  #39
vinnys coupe
lucky you..^^ whats the point behind heel and toeing?
4 months 2800 thats right where im shooting to be lol.. once summer comes thou its ganna be tuff beach like every other day and its not that close lol.. trieng to stick with low miles so in the future my car would be worth something..
Old Mar 24, 2008 | 03:00 PM
  #40
bnguyen85's Avatar
bnguyen85
Heel and toeing allows you to shift back into a lower gear. since you are going at a high speed and braking hard for a turn it would be hard to shift into a lower gear. If you force the shift you will grind your gears and mess up the syncros. Also it allows for less shift shock when going into a lower gear.
Old Mar 24, 2008 | 05:20 PM
  #41
shmad's Avatar
shmad
before u were told about double clutch downshifting. so think of that concept. now u add this in--->as ur slowing down for a corner, u press the brake w/ the ball of ur right foot, shift into neutral w/ ur left, blip the throttle w/ the heel of ur right foot, and then clutch into the lower gear. so ur braking, doubleclutch downshift (revmatching) all at the same time.
http://www.youtube.com/watch?v=IuoZeuSgEj4
Old Mar 24, 2008 | 06:25 PM
  #42
UNV-IT46's Avatar
UNV-IT46
the thing is you need to be going pretty fast and braking very hard for a true heel and toe to work correct. Other wise your going to be jerking on the brakes and everything will just go down hill from there
Old Mar 24, 2008 | 08:31 PM
  #43
vinnys coupe
i dk thats pretty sick, looks stuff to do.. maybe once i get a better feel of my clutch i can pull it off..
any 1 kno the right rpms to start downshifting..
does any1 ever drop to from like 5-3 or 6-4.. ?
Old Mar 25, 2008 | 01:34 AM
  #44
UNV-IT46's Avatar
UNV-IT46
yes i have gone 6-2 it all depends on what your doing and what pace your moving at
Old Mar 25, 2008 | 12:27 PM
  #45
vinnys coupe
wow, i didnt even think tha was possible.. can you make up an example when using that.. like around what rpm did u drop into 2. like 2k? adn then it jumped to around 5k?
