Motorsports / Track Th ultimate forum to discuss motorsports / track related topics for your G37.
Ran the 1/4 mile last night...
Old Jan 27, 2008 | 02:56 AM
DiamondGCoupe's Avatar
DiamondGCoupe
I haven't seen anything but from running 13.8s-.9s in my G35 consistantly I can only assume 13.5-.6 would be a good guess. AT BTW.
Old Jan 27, 2008 | 03:35 AM
NemesisG37's Avatar
NemesisG37
Originally Posted by cvt
trust me...the 07 Zs are much faster...100% stock they are getting down to 13.3s already...check out my350z.com for verified times. the HR Zs are mighty quick.
Give it time and our guys will be pulling impressive numbers as well.
Old Jan 27, 2008 | 03:50 AM
cvt's Avatar
cvt
Originally Posted by majin ssj eric
I haven't seen a stock G37 get under 13.7 yet.....
lowest time was actually posted on bimmer fest....13.75
Kahboom on this board already posted his time slip of 13.78 on an auto...
i think 13.6 someday will be possible, in the best possible conditions, with a great car and driver....i already posted a stock 07 G35 sedan getting 13.5s...
Old Jan 27, 2008 | 04:12 AM
NemesisG37's Avatar
NemesisG37
Word
Old Jan 27, 2008 | 12:25 PM
SilkeG's Avatar
SilkeG
Beating up on Cobalts at 2000 feet above sea, not bad. You've probably got the highest elevation run here. I wonder if the thinner air is harder for the G37 to launch given its weight?
Old Jan 27, 2008 | 02:40 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Yep higher elevations probably made a difference in this one. I am down not far from sea level. And the track is even closer to sea level.
Old Jan 27, 2008 | 07:38 PM
Titanium's Avatar
Titanium
You are assuming 13.5-6 based on what? That the G37 has 30hp more than the G35? Did you forget that it also weights 150lbs more?
Old Jan 27, 2008 | 08:06 PM
vinnys coupe's Avatar
vinnys coupe
yeah guys just give it time.. anything could have happend on this run..
but some1 is ganna go and make a decent run and make us look at the 37 as a diff car..
Ex one posted 14.3 or w.e other pasted 13.7
Soon to be under 13.7 just give it time fellaz i have faith in the 37 lol
Old Jan 27, 2008 | 08:54 PM
NemesisG37's Avatar
NemesisG37
G37s lb per hp 11.263
G35 lb per hp 11.825
Looks to me like the G37 is actually the "lighter one".
3717lb 330hp > 3524lb 298hp
Old Jan 27, 2008 | 09:41 PM
vinnys coupe
a good way to put it^^^
Old Jan 27, 2008 | 10:55 PM
SantiagoDraco's Avatar
SantiagoDraco
I guess that would assume that it scales that way. I don't know either way, but I'd bet that the "performance" varies above and below certain ratios. Someone who actually knows will have to answer that one ;D
Old Jan 27, 2008 | 11:02 PM
NemesisG37's Avatar
NemesisG37
I somewhat agree, but the G37 is a much better performer off and on the track.
Old Jan 27, 2008 | 11:41 PM
infidsg35's Avatar
infidsg35
I was running 14 flat with a 03 coupe which is 280 HP so the G37 has 50 more HP I better be in the 13's!!!
Old Jan 28, 2008 | 12:22 AM
  #29
NemesisG37's Avatar
NemesisG37
Its in the 13.75's..5AT
Old Jan 28, 2008 | 10:11 AM
  #30
RedlineSi's Avatar
RedlineSi
What are you guys using for launching techniques? For both Auto's and 6mts.
