DD Tail As Turn Mod
Old Jun 15, 2015 | 07:40 PM
  #31
bassy's Avatar
bassy
If I do this mod, can I replace the factory bulbs with LEDs and turn those blinkers into brake lights in addition to the twin factory LED rings? If yes, what else do I need to do that?
Old Jun 16, 2015 | 08:44 AM
  #32
Diode Dynamics's Avatar
Diode Dynamics
You would have to install an LED in place of the factory incandescent turn signal bulbs
Nick C.
Old Jun 16, 2015 | 11:48 AM
  #33
bassy's Avatar
bassy
Nick C.
OK, so which LED bulbs do I need to order? Do I need to splice or cut any wires to turn the blinkers into brake lights (i.e. they light up when I step on the brakes and go off when I step off)?
Does the PnP kit also turn the factory incandescent blinkers, which are no longer used as blinkers, into brake lights? That's what I want to do.
Do I need to go to your website to place an order? Or can I do it here?
Old Jun 16, 2015 | 11:55 AM
  #34
Diode Dynamics
I suggest giving us a call so we can clear the confusion you are having: (314) 205-3033
Make sure you watch the video as well
You won't be cutting anything with this plug and play kit. It converts the factory LED tail lights to act as both tail lights and turn signals (Hence the name, Tail-As-Turn™). You can leave the incandescent bulb in, but you'll have to remove the resistor if you do that. it will require more wiring if you wish to make the factory turn signal come on with the brake lights, and you'll need to install and LED.
Nick C.
Old Jun 17, 2015 | 08:46 AM
  #35
Diode Dynamics
The G35 Kit uses the same connector as the G37. Here's the video for more explanation:
Nick C.
Old Jun 17, 2015 | 10:07 AM
  #36
serega13's Avatar
serega13
This makes it look like a dodge avenger or caravan imho. I'm more interested in sequential turn signals so that they work like in a newer mustang only better looking due to more leds.
Old Jun 17, 2015 | 11:08 AM
  #37
Flakman's Avatar
Flakman
That would be cool to get it to circle around. Now THAT would be a mod!
Old Jun 17, 2015 | 11:59 AM
  #38
G37xhibeet's Avatar
G37xhibeet
Agreed, sequential would be much nicer on the G35
Old Jun 17, 2015 | 12:41 PM
  #39
AzNBoY92's Avatar
AzNBoY92
Installed and waiting for night time...
Old Jun 18, 2015 | 09:27 PM
  #40
AzNBoY92's Avatar
AzNBoY92
All I can say is wow love this way better than the stock turn and brake. Great little mod!
Old Jun 18, 2015 | 09:43 PM
  #41
Obsi's Avatar
Obsi
Hi I bought this module and noticed that when I press on the brake and turn on the signal, the front and rear signal lights blink alternately back and forth and not at the same time. If I turn just the signal on with no brakes everything is fine. Is anyone else having this issue or is it just me..? Not happy about this.
Old Jun 18, 2015 | 10:05 PM
  #42
AzNBoY92's Avatar
AzNBoY92
Okay just went to check mine and had the brake on on park, reverse and drive with the turn signal left and right and it worked fine. Maybe you got a bad kit or something else is messed up.
Old Jun 18, 2015 | 10:14 PM
  #43
Obsi's Avatar
Obsi
So your front and rear signal lights up at the same time when you have your foot on the brakes? Mine is blinking like an ambulance.
Old Jun 18, 2015 | 10:26 PM
  #44
AzNBoY92's Avatar
AzNBoY92
Whoops I guess I misread your post and yes mine does that too I wonder why it does this? Not that big of a problem for me but it is weird.
Old Jun 18, 2015 | 10:51 PM
  #45
Thirty_Seven's Avatar
Thirty_Seven
Thanks for bringing that up guys. Holding off on my purchase until DD responds.
