Springs
Old Nov 27, 2013 | 02:52 AM
tatos20's Avatar
tatos20
Springs
I got a stock height g37s 2013 coupe and now i'm looking for some lowering springs. What are some good spring that will lower my car a nice amount to almost no tire gap? And no i don't want coil over.
Old Nov 27, 2013 | 09:30 AM
Swift makes the highest quality springs for our car.
Old Nov 28, 2013 | 01:53 AM
tatos20's Avatar
tatos20
hows the drop tho?
Old Nov 28, 2013 | 02:07 AM
Gio37's Avatar
Gio37
Originally Posted by tatos20
hows the drop tho?
Swift springs installed PICS
g/l
Old Nov 28, 2013 | 02:25 AM
tatos20's Avatar
tatos20
Thanks and also would you recommend this over Eibach or H&R? keep in mind i will most likely keep my stock shocks considering its a 2 yr lease i don't want to drop too much money on the car.
Old Nov 28, 2013 | 09:40 PM
You'll also need F&R camber arms & a rear toe bolt kit if you want to have proper alignment after you lower it. The camber kit runs about $500 and expect to pay $120 for a 4 wheel alignment. That's assuming you DIY the install.
Old Nov 28, 2013 | 11:06 PM
evil-G-nius's Avatar
evil-G-nius
Why the eff are camber kits MORE than the damn springs!? That makes no sense to me. Anyone use ingalls kits? I have seen those for less...just curious
Old Nov 28, 2013 | 11:23 PM
I hear ya, it was a bitter pill for me to swallow but I wanted to make sure everything was proper when I dropped on springs a couple years ago. I'm glad I got them since I was pretty slammed on B&G springs, and am still pretty low on coilovers now. There's not much to those camber parts but they do command a stout price tag, guess they figure we gotta pay to play
Not sure about the Ingalls parts.
Old Nov 29, 2013 | 01:17 PM
Tim30250's Avatar
Tim30250
Well, the camber "kits" as we refer to them, are actually adjustable control arms. Pretty specialized and functional part, hence the expense. Springs are just, well.. springs. I'm lowered on Eibach and using SPC camber arms. They are high quality and allow the camber to be accurately dialed in. I'm not familiar with the ingalls brand, but the camber arms are a crucial suspension component, and I would not choose a cut rate brand unless they have proven quality. This is not an area you want to risk a part failure to save a few bucks..
Old Nov 29, 2013 | 02:12 PM
Well put^^
Another aspect to the cost of the camber sets is liability, I'm sure they have a pretty hefty liability premium when they manufacture parts as critical as a vehicles' alignment.
Old Dec 2, 2013 | 12:28 PM
evil-G-nius
Some cars have slightly adjustable camber arms from the factory...if you were to drop on just springs, you think there would be enough play to correct whatever negative camber?That way you could avoid having to pay that much for a kit? Is this the case with the G?
Old Dec 2, 2013 | 09:02 PM
The OEM front arms are fixed, no camber adjustment. The rear camber arms and toe bolts have a small concentric adjustment, not enough range to compensate for a mild spring drop though. You can make the camber & toe better but one or the other , or even both will be out of spec.
Old Dec 3, 2013 | 03:07 AM
evil-G-nius
Got ya...damn it! LOL
Old Dec 3, 2013 | 01:06 PM
malady's Avatar
malady
lol I hear ya
lowering my old car was so much easier >_<
Dillybar12
Nov 1, 2015 07:23 PM
si_driver
Oct 1, 2015 09:53 AM
si_driver
Sep 30, 2015 11:46 AM
djdiskino
Sep 29, 2015 07:18 PM
VIVID
Sep 29, 2015 10:58 AM
