Midwestern Serving CO, IA, IL, IN, KS, MI, MN, MO, MT, ND, NE, SD, UT, WI, WY
Modify G37 due to higher altitude?
Old Aug 20, 2010 | 10:07 PM
Seoul37's Avatar
Seoul37
Hey everyone. I just moved to Colorado a month ago and I was speaking to my co-worker who said he recommended that I at least put an K&N air filter due to the higher altitude in Northern Colorado. Doing so will make it so I get more air flow and thus get 10-15% more mileage.
Also, he said with this high of an altitude I don't have to fill on premium, but regular would be just fine (forgot what the reasoning was for that).
Old Aug 21, 2010 | 09:44 AM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Yes with the higher altitude you CAN go to 87/89 fuel...when I lived in CO I still put premium in my car just because. But you will notice a little less power at higher altitudes
Old Aug 29, 2010 | 08:57 PM
Seoul37's Avatar
Seoul37
Cool, thanks for the reply. As stupid as it sounds, what's the reasoning behind that (in terms of 87/89 being ok at a higher altitude)?
Old Aug 30, 2010 | 10:32 AM
hispeed-lowdrag
Don't quote me on it, but if I remember right it's because of flame point and combustion...because the reason you need 91/93 normally is so the fuel combusts at the correct timing in the cycle and you don't get knocking...and at a higher altitude with different pressure therefore different ignition and combustions points, you can use the lower grade fuel.
Old Aug 31, 2010 | 08:25 PM
zoner's Avatar
zoner
I would guess the air is thinner so compression ratio is less
Old Oct 11, 2010 | 11:52 PM
350z_drifter's Avatar
350z_drifter
i live in colorado springs,colorado ! yes you can use 85/87 to save on gas price but you will get better pretormance and mileage using 91 .
we should get a g37 club in colorado.
Old Nov 2, 2010 | 04:58 PM
Seoul37's Avatar
Seoul37
Hey sorry for the late reply. For sure, I swear I only seen maybe a handful of them around. I know I've seen one in norther colorado....me.
Old Nov 8, 2010 | 10:30 PM
350z_drifter
well there a couple down here i'm trying to see if there interested
Old Nov 18, 2010 | 12:33 AM
g35_red's Avatar
g35_red
I would rather pay the extra 10 cents per gallon in a 91 gas than saving 2 or 3 bucks in 87/85.
i am interested in a g37 colorado club.
Old Nov 19, 2010 | 02:02 AM
dal1307's Avatar
dal1307
Hey, have any of you guys ever dealt with MAC Autosport? I am in the Broomfield area and am thinking about having them install a SC in my 2008 G37S. I have a buddy with a G35 who had them install an intake and plenum spacer. He said they were great to work with and did a good job.
Old Nov 21, 2010 | 08:53 PM
350z_drifter
i had the work on my 240sx w sr20det
there okay but dont give great deals
pretty expensive
350z_drifter
do you guys have pictures of you g37
Old Dec 16, 2010 | 06:58 PM
dal1307's Avatar
dal1307
pretty expensive
Just spoke with them today and they are asking $7500 installed for the Stillen turnkey kit. They use the tune developed by Stillen for high altitude. That means they are getting around $1200 for the install. I don't know how many hours labor is actually involved.
Old Dec 16, 2010 | 07:00 PM
dal1307's Avatar
dal1307
I don't have any decent ones.
Old Dec 17, 2010 | 10:57 AM
Pip's Avatar
Pip
They did some work for me on a subie - installed an FMIC, bigger turbo, etc. They had to do some custom fabrication on the tubing - it all turned out well. I didn't have any problems with them. The owner is a gruff old b@stard, but the guys in the shop did good work.
