Infiniti Q50 Interior LED Conversion! See Comparison Photos! Plug & Play Install
Old Apr 3, 2017 | 04:31 PM
Diode Dynamics's Avatar
Diode Dynamics
Arrow Infiniti Q50 Interior LED Conversion! See Comparison Photos! Plug & Play Install
Infiniti Q50 LED Conversion Kit
At Diode Dynamics, we carry a full line of LED bulbs, to replace your Infiniti Q50's dome lights, vanity lights, license plate lights, and more!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Map lights, or the pair of lights above your front seats, use incandescent bulbs from the factory, giving them a yellowish color. By replacing these factory bulbs with LEDs, you can add a luxurious and modern look to your Infiniti Q50, with a cool white color, just like the map lights on newer luxury vehicles.
The installation is 100% plug-and-play, just replace your Infiniti Q50's factory bulb!
Bulb Design:
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
SMD12 Board: This is an LED panel, fitted with 12 5050-size Epistar SMD chips. Comes with 194/T10 adapter for direct installation. Plug the adapter into the bulb socket, then just stick the board in place with the mounting adhesive pad. The board-and-adapter design allows for extremely high brightness compared to a simple bulb.
Brightness
HP3: (56 lumens) Similar brightness to the OEM bulbs,
HP5: (92 lumens) Much higher brightness than OEM bulbs.
SMD12 Board: (118 lumens) Much brighter than OEM bulbs. These are bright!
Lumens: BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
All products by Diode Dynamics are backed by a 30-day satisfaction guarantee and a three-year limited warranty.
Dome Light LEDs for 2014-2016 Infiniti Q50 (pair)
Door Light LEDs for 2014-2016 Infiniti Q50 (pair)
Vanity Light LEDs for 2014-2016 Infiniti Q50 (pair)
Questions? Feel free to ask here, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
