Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Auto Detailing Expert
Today's Daily special (January 11, 2016) is DI Microfiber Waffle Weave Drying Towel.
Regular Price for 36" x 24" is $17.99. Today's price is $10.86!
Regular Price for 16" x 24" is $9.99. Today's price is $5.29!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- One of the best options for drying your vehicle safely and quickly
- Continues to soak up large amounts of water even after it's damp or wet
- A fine silk edging ensures this is a safe towel
- This towel can hold up to 10 times its weight with water
- Use this towel with the sheeting method for the most efficient drying process
- 480 GSM
Today's Daily special (January 12, 2016) is 303 Automotive Protectant Wipes.
Regular Price is $7.99. Today's price is $5.77!
- Convenient way to apply 303 Automotive Protectant
- Dress and protect your for vinyl, leather, rubber and plastic surfaces
- Contains 40 pre-moistened wipes
Today's Daily special (January 13, 2016) is CarPro Tar X Tar & Adhesive Remover.
Regular Price for 500 ml is $16.99. Today's price is $11.70!
Regular Price for 5 L is $99.99. Today's price is $79.11!
- Extremely effective product to remove tar! Also helps safely remove bug smear, road grime, brake dust,
- Citrus based cleaner that is non corrosive
- Thicker viscosity means it clings to the paint better and doesn't run easily
- Can be used safely all over the exterior
- Unique "glow color tracer" literally leaves a neon green glow wherever it's sprayed
Today's Daily special (January 14, 2016) is 303 Fabric Guard.
Regular Price for 16 oz is $12.99. Today's price is $9.42!
Regular Price for 32 oz is $19.99. Today's price is $15.44!
Regular Price for 128 oz is $76.99. Today's price is $58.78!
- Protects carpet, canvas and upholstery from staining by repelling liquids
- Makes maintaining interior carpets, floor mats and canvas seats significantly easier when protected
- Works great on canvas convertible tops and outdoor patio furniture
- For maximum efficiency use in a 4oz pump spray bottle
- Formally known as the 303 High Tech Fabric Guard
Today's Daily special (January 15, 2016) is Meguiar's DA Microfiber Finishing Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $16.08!
Regular Price for 6.25" is $23.99. Today's price is $17.54!
Regular Price for 3" is $13.99. Today's price is $10.23!
- Use this pad to apply the Meguiar's DA Microfiber Finishing Wax
- Includes 2 Pads
- Outstanding polishing power that provides a high level of gloss
- Microfiber buffing pads are changing the way detailers work
- Use it with the Meguiar's Soft Buff DA Backing Plate
Today's Daily special (January 18, 2016) is Menzerna 3in1 Cut, Gloss & Wax.
Regular Price for 8 oz is $19.99. Today's price is $14.30!
Regular Price for 32 oz is $44.99. Today's price is $32.48!
- An incredible one step polish and protection product!
- Finishes down very well creating a glossy appearance
- Excellent polishing power to remove swirls, oxidation, etc.
- Leaves behind a great deal of gloss and carnauba wax protection
Today's Daily special (January 19, 2016) is Lake Country Rayon Glass Polishing Pad.
Regular Price for 5" is $4.99. Today's price is $3.37!
Regular Price for 3" is $3.99. Today's price is $2.52!
- Polish away fine scratches, water marks, sap and contamination from your glass
- Rotary buffers can achieve maximum results
- Hook and loop backing for easy fastening
- Works great with the CarPro Ceriglass Glass Polish
Today's Daily special (January 22, 2016) is DI Microfiber Glass Polishing Towel (Blue).
Regular Price for 16" x 16" is $5.99. Today's price is $3.30!
- The ideal solution for achieving that streak free finish when caring for glass
- Use a slow wiping motion, while applying some pressure to the glass polishing towel
- The low, ultra thin nap ensures that there is no lint left behind on glass
- Ideally, use a separate towel to apply your favorite glass cleaner and initially wipe dry
- Always wash your microfiber products prior to first use and remove tags to ensure paint safe
- 240 GSM
Today's Daily special (January 26, 2016) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5" is $11.99. Today's price is $7.95!
Regular Price for 5" is $9.99. Today's price is $6.47!
Regular Price for 4" is $5.99. Today's price is $4.59!
- Our most cutting pad option, however, due to the wool strands, not as much heat is generated
- Works best on high powered buffers, for fast, effective paint correction
- Commonly used with a medium or heavy cut compound to remove deep imperfections and wet sanding marks
- We recommend caring for your pads with Snappy Clean Pad Cleaner
Today's Daily special (January 27, 2016) is DI Accessories Nitrile Gloves Powder Free Black (100 pack).
Regular Price for Large is $17.99. Today's price is $12.25!
Regular Price for Medium is $17.99. Today's price is $12.25!
- Very soft and flexible glove designed to fit all adult male hands
- Protects your hands from moisture and strong cleaning agents
- 100% latex free glove
- Slightly textured surface allows you to grip with ease
- Each box has 100 gloves or 50 pairs
Today's Daily special (January 28, 2016) is Dodo Juice Born Slippy Clay Lube Concentrate.
Regular Price for 250 ml is $15.99. Today's price is $11.72!
- Ultra concentrated solution makes for over 2.5 liters of clay lube
- Dilute up to a 10:1 ratio with water while remaining super slick
- Wipes away streak free and is safe for nearly any surface
- We recommend picking up a 22oz spray bottle for proper dilution
Today's Daily special (January 29, 2016) is 3M Automotive Masking Tape.
Regular Price for 18 mm is $3.99. Today's price is $2.86!
- Quality masking tape for protecting your trim, paint and more!
- Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
- Great value!
Today's Daily special (February 1, 2016) is Chemical Guys Maxi Suds II.
Regular Price for 16 oz is $8.99. Today's price is $5.56!
Regular Price for 128 oz is $24.99. Today's price is $15.65!
- One of our best selling shampoos, lots of foam, great lubricity, and gentle cleaning power
- An addicting cherry scent that makes washing your car a pleasure
- Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
- High sudsing formula makes this a great option to use in foam guns
Today's Daily special (February 2, 2016) is DI Accessories Bug Sponge.
Regular Price is $2.99. Today's price is $1.80!
- Remove dirt, grime, bug splatter, and more
- High quality, soft, durable foam
- Easily rinses clean
Today's Daily special (February 3, 2016) is Lake Country HD Orbital Blue Cutting Pad.
Regular Price for 6" is $13.99. Today's price is $9.53!
Regular Price for 7" is $15.99. Today's price is $10.89!
- The most aggressive LC HD Pad, designed to remove heavy scratches, swirls, and defects.
- Runs 10% cooler than traditional Lake Country pads
- Perfectly balanced, cushioned, and features thinner foam
- Removes imperfections easily while reducing hazing and marring from heavier polishing compounds
