Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Auto Detailing Expert
Today's Daily special (May 20, 2015) is DI Accessories Razor Blade and Mini Plastic Holder.
Regular Price is $1.99. Today's price is $1.09!
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
- Pocket size plastic scraper with one single edge razor blade
- Quickly remove inspection stickers and registration stickers
- Use for virtually any scraping, trimming, or cutting
- Open or close with easy push button lock system
Today's Daily special (May 21, 2015) is Menzerna Super Finish Polish SF 4000.
Regular Price for 16 oz is $29.99. Today's price is $21.97!
Regular Price for 32 oz is $44.99. Today's price is $34.80!
- One of our favorite polishes that removes, oxidation, swirls and light imperfections
- Easy to use with long work times and easy removal
- Most commonly applied with a White or Tangerine Lake Country Pad for a great combination of polishing power and gloss
- Super Finish Polish SF 4000 helps create the shine which you can enhance with any sealant or wax afterward
Today's Daily special (May 22, 2015) is DI Brushes Leather and Vinyl Scrub Brush.
Regular Price is $3.99. Today's price is $2.73!
- Outstanding leather care brush to deep clean leather!
- Works great with all leather care products, especially the Leatherique Prestine Clean and Leatherique Rejuvenator Oil
- Soft and gentle leather brush that works great
Today's Daily special (May 26, 2015) is Rupes White Finishing Foam Pad.
Regular Price for 4" is $9.99. Today's price is $6.47!
Regular Price for 6" is $12.99. Today's price is $8.55!
Regular Price for 7" is $14.99. Today's price is $9.47!
- Bring back that deep glossy finish safely and easy!
- Removes ultra fine imperfections and finishes down extremely well
- Pairs great with the Rupes Diamond Ultra Fine Gel Polish
Today's Daily special (May 27, 2015) is DI Microfiber Grey on Gray Towel.
Regular Price for 16" x 16" is $3.99. Today's price is $2.30!
- Tight weave and low/medium nap for easy removal of polish, wax, sealants, etc
- Can be used to clean and apply virtually any product
- Use it on the vehicle's interior and around the home!
- Soft fibers are safe and effective!
- Can be washed hundreds of times, we recommend Micro-Restore Microfiber Detergent Concentrate
- 307 GSM
Today's Daily special (May 28, 2015) is DI Brushes Heavy Duty Wheel Brush.
Regular Price is $4.99. Today's price is $3.22!
- Clean even the heaviest of build ups off your wheels quickly and easily
- The stiff blue polypropylene bristles provide extra scrubbing action
- With a simple rinse this brush is clean for future uses
Today's Daily special (May 29, 2015) is Chemical Guys Meticulous Matte Detailer (MMD).
Regular Price for 16 oz is $19.99. Today's price is $12.05!
- Finally a product designed to care for matte and flat finishes
- Helps clean and protect in one easy step
- Spray it on a microfiber towel or directly on the surface and wipe with light pressure
- Will not leave any white residue behind
- Contains no waxes or silicone
Today's Daily special (June 1, 2015) is DI Brushes Toothbrush Style Detail Brush.
Regular Price is $1.99. Today's price is $1.17!
- Remove dirt and debris from small seams and crevices safely and easily!
- Easy to grip plastic handle with grooved "finger-grips"
- Soft and safe horse hair bristles
- Durable construction for regular usage
Today's Daily special (June 2, 2015) is DI Microfiber Black and Yellow Towel.
Regular Price for 16" x 16" is $4.99. Today's price is $3.09!
- Two sided towel that is perfect for cleaning inside and out
- Plush on one side with a shorter nap on the other
- Tag less design with bounded edges for added durability
- Safely and easily removes polishes, sealants, waxes, etc.
- Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
- 407 GSM
Today's Daily special (June 3, 2015) is Chemical Guys Window Clean.
Regular Price for 16 oz is $6.99. Today's price is $4.51!
- A tint safe window cleaner that cuts through grime and leaves windows streak free
- Best applied with a microfiber towel and followed up with a glass microfiber towel
Today's Daily special (June 4, 2015) is DI Microfiber Two Sided Large Towel.
Regular Price for 16" x 24" is $4.99. Today's price is $2.99!
- This two sided towel is perfect for cleaning a variety of surfaces!
- One of our largest microfiber towels measuring 16" x 24"
- Silk edging helps minimize adding imperfections to delicate surfaces
- We always recommend washing your microfiber products before the first use (ie DI Microfiber Micro-Restore Microfiber Detergent Concentrate)
- 365 GSM
Today's Daily special (June 5, 2015) is CarPro Iron X Iron Remover Lemon Scent.
Regular Price for 500 ml is $18.99. Today's price is $11.91!
Regular Price for 1000 ml is $29.99. Today's price is $20.01!
Regular Price for 4 L is $99.99. Today's price is $67.35!
- This is the MUST have product for ALL detailers!
- Remarkably quick and effective cleaner for the exterior paint and wheels
- Mist Iron X on the exterior and watch it safely dissolve embedded iron deposits
- pH balanced and gentle formula safe to use over virtually the entire exterior
- Turns a deep and dark red color as it dissolves particles stuck to the surface
- Lemon scented with improved formula!
- Also available in Cherry Scent!
Today's Daily special (June 8, 2015) is Meguiar's Soft Buff DA Foam Polishing Disc.
Regular Price for 5" is $10.99. Today's price is $7.67!
Regular Price for 6" is $12.99. Today's price is $9.07!
- Polishing disc that makes quick work of medium to light imperfections!
- Low operating temperature and less haze left behind
- Thin 17.5mm disc design
- Works on the MT300 or any other DA Polisher
- Perfect fit on the Soft Buff DA Backing Plate
Today's Daily special (June 9, 2015) is Lake Country Hydro Tech Cyan Light Cutting & Polishing Pad.
Regular Price for 6.5" is $11.99. Today's price is $7.31!
Regular Price for 5.5" is $9.99. Today's price is $6.24!
Regular Price for 4" is $5.99. Today's price is $3.80!
Regular Price for 3" is $3.99. Today's price is $2.49!
- Powerful cutting action but the ability to finish down haze free
- Hydro Tech foam keeps more polish on the surface of the pad for longer work time
- Experience less dusting than traditional foam pads due to less product build up
- Lake Country Snappy Clean Pad Cleaner help clean these pads
- Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
Today's Daily special (June 10, 2015) is DI Microfiber Ultra Plush Two Sided Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.25!
- Our most popular towel for applying quick detailers, plush on one side and medium nap on the other
- Works excellent as an interior duster towel which you can easily store in your glove compartment
- Perfect for giving those final wipe downs after removing a sealant or wax
- 530 GSM
