Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Old May 5, 2014 | 07:35 AM
  #826
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Today's Daily special (May 5, 2014) is Chemical Guys Sofast Odor Eater.
Regular Price for 16 oz is $8.99. Today's price is $6.47!
  • Remove odors from your interior by killing the bacteria causing the foul smell
  • Leaves behind a fresh apple scent that lingers for days
  • To maximize your product, we recommend using a 4oz pump spray bottle to dispense
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old May 6, 2014 | 08:03 AM
  #827
Detailed Image
Today's Daily special (May 6, 2014) is DI Microfiber Double Thick Edgeless Towel.
Regular Price for 16" x 16" is $5.99. Today's price is $4.37!
  • Edgeless design saves you time while improving results!
  • Very plush, long, and soft microfiber threads
  • Very durable design that can be machine washed
  • Can be used for virtually any detailing task
  • 470 GSM
Old May 7, 2014 | 08:19 AM
  #828
Detailed Image
Today's Daily special (May 7, 2014) is Blackfire Total Polish and Seal.
Regular Price for 16 oz is $19.99. Today's price is $14.59!
  • Cleans, shines and protects in one step!
  • Polishes the surface and leaves behind the Wet Diamond polymers for protection
  • You only need about one ounce per coat, so it's a great value!
  • Applies and removes with ease
  • Pleasant scent makes working with this product fun!
Old May 8, 2014 | 08:40 AM
  #829
Detailed Image
Today's Daily special (May 8, 2014) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.35!
Regular Price for 32 oz is $19.99. Today's price is $14.19!
Regular Price for 128 oz is $57.99. Today's price is $41.17!
Regular Price for 10 oz is $7.99. Today's price is $5.83!
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Old May 9, 2014 | 08:04 AM
  #830
Detailed Image
Today's Daily special (May 9, 2014) is Leatherique Rejuvenator Oil.
Regular Price for 16 oz is $31.99. Today's price is $24.00!
Regular Price for 32 oz is $49.99. Today's price is $37.24!
Regular Price for 8 oz is $18.99. Today's price is $13.48!
  • Detailed Image's best leather care product to restore neglected, faded, hardened leather
  • Restores oils and proteins that are naturally found in leather for a soft and supple feel
  • Works best when allowed to penetrate leather for up to 48 hours, ideally in the heat
  • Using a hair drier to heat up the leather surface allows for maximum penetration and best results
  • Apply Rejuvenator Oil by massaging the product into the leather with your bare hands
  • Must be removed by following up with Leatherique Prestine Clean
Old May 12, 2014 | 07:27 AM
  #831
Detailed Image
Today's Daily special (May 12, 2014) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.43!
  • Safely and effectively remove tar, grease and sap from painted surfaces
  • Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
  • Remember to protect the areas you use Tarminator on with a sealant or wax
Old May 13, 2014 | 08:24 AM
  #832
Detailed Image
Today's Daily special (May 13, 2014) is Chemical Guys Microfiber Wash Cleaning Detergent.
Regular Price for 128 oz is $32.99. Today's price is $24.58!
  • Restore your microfiber to a like new condition every wash
  • Helps extend the life of your microfiber towels by keeping them fresher longer
  • Works great with any microfiber product: towel, applicator, mitt, etc.
Old May 14, 2014 | 08:10 AM
  #833
Detailed Image
Today's Daily special (May 14, 2014) is Dodo Juice Red Mist Tropical Protection Detailer.
Regular Price for 250 ml is $16.99. Today's price is $12.57!
Regular Price for 500 ml is $29.99. Today's price is $22.19!
  • Extend the protection of any sealant or wax
  • Increase gloss and depth of your paint, perfect for after a wash
  • Promotes tight water beading which helps minimize water spots
  • Applies and removes easy with a plush microfiber towel
Old May 15, 2014 | 08:15 AM
  #834
Detailed Image
Today's Daily special (May 15, 2014) is Tuf Shine Tire Clearcoat.
Regular Price for 6 oz is $24.99. Today's price is $18.24!
Regular Price for 16 oz is $44.99. Today's price is $32.84!
  • The longest lasting tire shine we have ever tested, lasts several months at a minimum
  • 1 - 2 coats gives you a beautiful matte finish, 3+ coats gives you an incredibly glossy finish
  • Water based formula that is totally safe, no petroleum solvents, silicones or oils that can attract dust
  • Comes with applicator
  • To get the Tire Clearcoat and more check out the TUF SHINE Tire Appearance Kit
  • Withstands several pressure washing treatments and can be washed with gentle cleaners
Old May 16, 2014 | 08:03 AM
  #835
Detailed Image
Today's Daily special (May 16, 2014) is Stoner Invisible Glass.
Regular Price for 19 oz is $5.99. Today's price is $4.46!
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old May 20, 2014 | 08:26 AM
  #836
Detailed Image
Today's Daily special (May 20, 2014) is DI Microfiber Detailing Apron.
Regular Price is $19.99. Today's price is $14.39!
  • Protect your paint from metal and plastic clothing pieces
  • Made of ultra soft microfiber that is paint safe
  • One size fits all design
  • Two large pockets for easy access of any tools, products, or microfiber towels you are using
  • 300 GSM
Old May 21, 2014 | 08:21 AM
  #837
Detailed Image
Today's Daily special (May 21, 2014) is DI Brushes Fender and Grill Brush.
Regular Price is $4.99. Today's price is $3.54!
  • Safely remove built up dirt and grime from your grill
  • Soft natural tampico bristles will not mar or scratch the surface
  • 8.5" durable foam block handle
Old May 22, 2014 | 08:17 AM
  #838
Detailed Image
Today's Daily special (May 22, 2014) is Gilmour Brass Connector High Flow Shut-off Valve.
Regular Price is $7.99. Today's price is $5.75!
  • Easily kill water flow with a simple twist of a **** instead of walking back to the hose source
  • Perfect for removing your hose nozzle or foam gun to utilize the sheeting method
Old May 23, 2014 | 07:59 AM
  #839
Detailed Image
Today's Daily special (May 23, 2014) is DI Microfiber Micro-Restore Microfiber Detergent Concentrate.
Regular Price for 32 oz is $14.99. Today's price is $11.09!
Regular Price for 128 oz is $34.99. Today's price is $25.19!
  • Microfiber, cotton, chamois and towel revitalizer
  • Breaks down heavy wax, oil and grease
  • Contains no bleach or fabric softeners
  • Use 2 ounces for full loads or 1 ounce for smaller loads
  • Biodegradable
Old May 27, 2014 | 07:40 AM
  #840
Detailed Image
Today's Daily special (May 27, 2014) is DI Microfiber Black and Yellow Towel.
Regular Price for 16" x 16" is $4.99. Today's price is $3.54!
  • Two sided towel that is perfect for cleaning inside and out
  • Plush on one side with a shorter nap on the other
  • Tag less design with bounded edges for added durability
  • Safely and easily removes polishes, sealants, waxes, etc.
  • Can be cleaned with the Micro-Restore Microfiber Detergent Concentrate
  • 407 GSM
