Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Old Jan 11, 2013 | 08:06 AM
  #511
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Today's Daily special (January 11, 2013) is DI Accessories Yellow Foam Applicator Pad.
Regular Price is $1.49. Today's price is $1.07!
  • Most commonly used for applying polishes, glazes, sealants, and waxes!
  • Helps you apply a thin and even coating over any surface for maximum results
  • Washable and reusable so they provide a great value for years to come
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Jan 14, 2013 | 07:53 AM
  #512
Detailed Image
Today's Daily special (January 12, 2013) is Little Trees New Car Air Freshener.
Regular Price is $1.49. Today's price is $1.06!
  • Instantly reminds you of the new car smell that is clean and fresh
  • Proudly made in the USA
  • Amazing scent that easily lasts several weeks
  • One of the most popular Little Trees scents
Old Jan 14, 2013 | 08:08 AM
  #513
Detailed Image
Today's Daily special (January 14, 2013) is DI Microfiber Great White Towel.
Regular Price for 16" x 24" is $6.99. Today's price is $4.96!
  • The perfect work horse towel, that can remove product residue, as well as apply liquid products
  • Larger 24" x 16" towel provides more surface area to collect and trap product, dust, dirt and more
  • Silk edging helps minimize adding imperfections to delicate surfaces
  • Always wash your microfiber products prior to first use, ideally with CG Microfiber Detergent
Old Jan 15, 2013 | 08:07 AM
  #514
Detailed Image
Today's Daily special (January 15, 2013) is Chemical Guys Bug Bugger & Tar Remover.
Regular Price for 16 oz is $8.99. Today's price is $6.65!
  • Remove tar, bug splatter, sap, road grime, brake dust, bird droppings, pollutants, oil and so much more
  • Excellent shampoo also known as the Chemical Guys Strong Wash
  • Safely and effectively removes surface contaminants while washing
  • Mix three cap fulls or less with each gallon of water for a powerful shampoo solution
  • Use to spot treat build ups when diluted ten to one
Old Jan 16, 2013 | 08:10 AM
  #515
Detailed Image
Today's Daily special (January 16, 2013) is Meguiar's Self Cleaning Dispenser Bottle.
Regular Price for 16oz is $3.49. Today's price is $2.60!
  • A self cleaning dispenser bottle that helps you work faster and neatly
  • Purchase larger sizes of your favorite products and pour them in a convenient dispenser bottle
  • Dispenses exactly the right amount of product each time
  • Will not clog and you won't get dried out product left in the tip
Old Jan 17, 2013 | 08:08 AM
  #516
Detailed Image
Today's Daily special (January 17, 2013) is Leatherique Prestine Clean.
Regular Price for 16 oz is $19.99. Today's price is $15.68!
Regular Price for 32 oz is $29.99. Today's price is $22.62!
  • A premium leather cleaner with light conditioners, perfect for cleaning and maintaining leather
  • Restores proteins that are naturally found in leather for a soft and supple feel
  • Completely matte finish that has no greasy or oily residue
  • Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and wipe dry with a second towel
  • For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
Old Jan 18, 2013 | 07:58 AM
  #517
Detailed Image
Today's Daily special (January 18, 2013) is Dodo Juice Lime Prime Lite Cleaner Glaze.
Regular Price for 250 ml is $19.99. Today's price is $15.07!
  • A non-abrasive pre-wax cleaner that brightens paint and properly preps it for waxing
  • Helps increase the depth and gloss of any color paint after claying or polishing
  • Works best when topped with a carnauba wax, especially the Dodo Juice waxes
  • When using a buffer, best applied with a black or blue finishing pad
  • Can be applied with a foam applicator pad and removed with a quality microfiber towel
Old Jan 21, 2013 | 08:05 AM
  #518
Detailed Image
Today's Daily special (January 21, 2013) is Gilmour Brass Quick Connector Set.
Regular Price is $9.99. Today's price is $7.82!
  • Connect your hose to any attachments in literally just a second!
  • Made of heavy duty brass
  • Rubber grips for easy handling
  • Will make changing out hose nozzles a breeze!
  • Allows the hose nozzle to rotate in your hand freely
Old Jan 22, 2013 | 08:07 AM
  #519
Detailed Image
Today's Daily special (January 22, 2013) is Lake Country Hydro Tech Cyan Light Cutting and Polishing Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.63!
Regular Price for 5.5 inch is $9.99. Today's price is $7.19!
Regular Price for 4 inch is $5.99. Today's price is $4.43!
Regular Price for 3 inch is $3.99. Today's price is $2.95!
  • Powerful cutting action but the ability to finish down haze free
  • Hydro Tech foam keeps more polish on the surface of the pad for longer work time
  • Experience less dusting than traditional foam pads due to less product build up
  • Lake Country Snappy Clean Pad Cleaner help clean these pads
  • Works great with the Meguiar's Ultra-Cut Compound M105 and the Menzerna Super Intensive Polish SI 1500 (PO83)
Old Jan 23, 2013 | 08:09 AM
  #520
Detailed Image
Today's Daily special (January 23, 2013) is TUF SHINE Tire Cleaner.
Regular Price for 22 oz is $9.99. Today's price is $7.44!
Regular Price for 128 oz is $39.99. Today's price is $28.39!
Regular Price for 128 oz Conc is $59.99. Today's price is $42.59!
  • Excellent tire cleaner that releases road grime and old tire dressing residue
  • Use it with the TUF SHINE Tire Brush for optimal results
  • Make sure you use this cleaner before applying the TUF SHINE Tire Clearcoat
  • 128 oz Conc size is concentrated and can be diluted 1:1 for maximum value
Old Jan 24, 2013 | 08:03 AM
  #521
Detailed Image
Today's Daily special (January 24, 2013) is Dodo Juice Sour Power Gloss Enhancing Shampoo.
Regular Price for 250 ml is $13.99. Today's price is $10.78!
  • Perfect maintenance shampoo that enhances gloss and depth
  • Lots of lubricity and slickness to help minimize adding imperfections
  • Concentrated formula means only a little product is needed per wash
  • Best used with a grout sponge or sheepskin wash mitt
Old Jan 25, 2013 | 08:05 AM
  #522
Detailed Image
Today's Daily special (January 25, 2013) is Lake Country Tire Dressing Applicator.
Regular Price is $1.99. Today's price is $1.45!
  • A perfect applicator pad to apply your favorite tire dressing
  • Firm foam design that will not shred like cheaper tire dressing applicator pads
  • Works excellent with Poorboy's Bold 'n Bright water based tire dressing
Old Jan 28, 2013 | 08:06 AM
  #523
Detailed Image
Today's Daily special (January 28, 2013) is Clay Magic Fine Grade Clay Bar.
Regular Price for 200 g is $24.99. Today's price is $18.24!
  • Fine grade clay bar that is one of the standards in the industry for enthusiasts and professionals
  • Remove embedded surface contamination that does not come off during the washing process
  • Properly preps your paints surface for polishing, using a glaze, sealant and / or wax
  • Helps you get the most out of any step you perform after using the clay bar
  • Use with plenty of clay bar lubricant to minimize any micro-marring that may occur
  • We recommend using Poorboy's Spray & Wipe as a clay bar lubricant and quick detailer
Old Jan 29, 2013 | 08:17 AM
  #524
Detailed Image
Today's Daily special (January 29, 2013) is Menzerna Paint Refresh Professional Grade Detail Spray.
Regular Price for 22 oz is $23.99. Today's price is $17.51!
  • Cleans, shines, and protects your paint all in one step
  • Safe for painted surfaces, glass, plastic, chrome, etc.
  • Quickly removes dust, dirt, fingerprints, and light contamination
  • Leaves behind a layer of protection and anti-static properties
Old Jan 30, 2013 | 08:10 AM
  #525
Detailed Image
Today's Daily special (January 30, 2013) is Chemical Guys Citrus Wash.
Regular Price for 16 oz is $9.99. Today's price is $7.44!
Regular Price for 128 oz is $32.99. Today's price is $24.08!
  • Ultra concentrated paintwork cleaning shampoo designed to strip off protection to start fresh
  • Powerful concentrated formula only requires 1oz of product per gallon of water to effectively remove layers of protection
  • Works well in a Gilmour Foam Gun
