Special New Special Every Day At www.DetailedImage.com on Top Quality Car Care Products!
Old Aug 9, 2011 | 08:10 AM
  #166
Detailed Image's Avatar
Detailed Image
Auto Detailing Expert
Today's Daily special (August 9, 2011) is TUF SHINE Tire Appearance Kit.
Regular Price is $39.99. Today's price is $29.79!
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone's that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Aug 10, 2011 | 08:02 AM
  #167
Detailed Image
Today's Daily special (August 10, 2011) is TUF SHINE Tire Cleaner.
Regular Price for 22 oz is $9.99. Today's price is $7.44!
  • Excellent tire cleaner that releases road grime and old tire dressing residue
  • Use it with the TUF SHINE Tire Brush for optimal results
  • Make sure you use this cleaner before applying the TUF SHINE Tire Clearcoat
Old Aug 11, 2011 | 08:00 AM
  #168
Detailed Image
Today's Daily special (August 11, 2011) is Meguiar's Backing Plate 3" with Adapter Kit.
Regular Price is $22.99. Today's price is $17.13!
  • 3" Backing Plate that works great in tight spaces
  • Commonly used with the Meguiar's 3" Pads or any pad 3" - 4" in diameter
  • Use it on the spoiler, front bumper, side mirrors, door jambs, etc.
  • Can also be used with sanding tools as it comes with several different threadings
Old Aug 14, 2011 | 04:59 PM
  #169
Detailed Image
Today's Daily special (August 14, 2011) is Dodo Juice Time to Dry Drying Detailer.
Regular Price for 250 ml is $12.99. Today's price is $11.79!
  • Dry your paint faster and more effectively
  • Helps minimize adding imperfections during wipe downs
  • Reduce potential water spots on your paint
  • Best used in conjunction with a waffle weave drying towel
Old Aug 15, 2011 | 06:58 AM
  #170
Detailed Image
Today's Daily special (August 15, 2011) is Meguiar's DA Microfiber Cutting Disc Buffing Pad - 2 pack.
Regular Price for 5.5" is $21.99. Today's price is $15.61!
Regular Price for 6.25" is $23.99. Today's price is $17.03!
Regular Price for 3" is $11.99. Today's price is $8.51!
  • Combine this pad with the Meguiar's DA Microfiber Correction Compound for best results
  • Includes 2 Pads
  • Exceptional cutting power that removes swirls while finishing down crystal clear
  • A brand new technology that is changing the detailing world
  • Use a Porter Cable 7424 XP and the Meguiar's Professional Backing Plate
Old Aug 16, 2011 | 08:08 AM
  #171
Detailed Image
Today's Daily special (August 16, 2011) is Chemical Guys GlossWorkz Paintwork Cleanser.
Regular Price for 16 oz is $12.99. Today's price is $10.21!
Regular Price for 128 oz is $42.99. Today's price is $33.90!
  • Extends the protection of your sealant or wax while enhancing the gloss and depth of your paint
  • Used like a shampoo, GlossWorkz is a pH balanced, biodegradable, detergent free and non-toxic paintwork cleanser
  • Use 1 oz per 4 to 5 gallons of water
Old Aug 17, 2011 | 08:09 AM
  #172
Detailed Image
Today's Daily special (August 17, 2011) is Chemical Guys Celeste Dettaglio Paste Wax.
Regular Price for 8 oz is $174.99. Today's price is $125.99!
  • When your car demands a deep, wet, glossy finish, that is easy to apply and remove look no further than Celeste
  • Rivals results from other high end carnauba waxes that cost over 5x as much!
Old Aug 18, 2011 | 08:11 AM
  #173
Detailed Image
Today's Daily special (August 18, 2011) is Stoner Tarminator.
Regular Price for 10 oz is $5.99. Today's price is $4.25!
  • Safely and effectively remove tar, grease and sap from painted surfaces
  • Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
  • Remember to protect the areas you use Tarminator on with a sealant or wax
Old Aug 19, 2011 | 07:58 AM
  #174
Detailed Image
Today's Daily special (August 19, 2011) is Lake Country Purple Foamed Wool Pad.
Regular Price for 6.5 inch is $11.99. Today's price is $8.87!
Regular Price for 5.5 inch is $9.99. Today's price is $7.19!
Regular Price for 4 inch is $5.99. Today's price is $4.79!
  • Our most cutting pad option, however, due to the wool strands, not as much heat is generated
  • Works best on high powered buffers, for fast, effective paint correction
  • Commonly used with a heavy cut compound to remove deep imperfections and wet sanding marks
  • We recommend caring for your pads with Snappy Clean Pad Cleaner
Old Aug 21, 2011 | 01:25 PM
  #175
Detailed Image
Today's Daily special (August 21, 2011) is Dodo Juice Born Slippy Clay Lube Concentrate.
Regular Price for 250 ml is $12.99. Today's price is $9.22!
  • Ultra concentrated solution makes for over 2.5 liters of clay lube
  • Dilute up to a 10:1 ratio with water while remaining super slick
  • Wipes away streak free and is safe for nearly any surface
  • We recommend picking up a 22oz spray bottle for proper dilution
Old Aug 22, 2011 | 06:56 AM
  #176
Detailed Image
Today's Daily special (August 22, 2011) is 303 Aerospace Protectant.
Regular Price for 16 oz is $12.99. Today's price is $9.68!
Regular Price for 32 oz is $22.99. Today's price is $17.01!
Regular Price for 128 oz is $57.99. Today's price is $42.91!
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Old Aug 23, 2011 | 08:09 AM
  #177
Detailed Image
Today's Daily special (August 23, 2011) is TUF SHINE Scrub-All No Scratch Sponge.
Regular Price is $1.99. Today's price is $1.48!
  • Quickly and safely remove bug smear, road grime, tar and more!
  • A durable and reusable sponge that will last
  • Extra strong and very gentle
Old Aug 25, 2011 | 08:01 AM
  #178
Detailed Image
Today's Daily special (August 25, 2011) is Chemical Guys Stripper Scent - Smell of Success.
Regular Price for 16 oz is $11.99. Today's price is $9.30!
  • Extra pleasant smell sure to please all!
  • This product comes with a happiness warning!
  • Active odor eliminators will subdue unpleasant smells at the source
Old Aug 26, 2011 | 08:16 AM
  #179
Detailed Image
Today's Daily special (August 26, 2011) is Poorboy's World Bold 'n Bright.
Regular Price for 16 oz is $10.99. Today's price is $8.19!
Regular Price for 32 oz is $17.99. Today's price is $13.40!
  • Water based tire dressing that gets absorbed into your tires and minimizes sling on to your paint
  • Maintains the flexibility of your tires, compared to silicone dressings that can dry them out
  • Best applied with a Lake Country tire dressing applicator pad
  • For maximum durability and shine, prep your tires with Poorboy's Bio APC prior to application
Old Aug 30, 2011 | 07:04 AM
  #180
Detailed Image
Today's Daily special (August 30, 2011) is Meguiar's Ultra Finishing Polish M205.
Regular Price for 32 oz is $27.99. Today's price is $21.14!
Regular Price for 128 oz is $84.99. Today's price is $61.19!
Regular Price for 8 oz is $9.49. Today's price is $6.93!
  • Removes swirls and light imperfections on any type of paint
  • Finishes down haze, hologram and marring free
  • Perfect follow up to Meguiar's Ultra Cut Compound 105
  • Commonly used with a white polishing pad or a black finishing pad
