Custom Lime Green Stitched Wheel/Shift Boot by CFElement
Just finished this up tonight for a customer. Stock g wheel done with a lime green stitch on the wheel and shift boot. Anyone interested hit me up. Can also do cf on some parts of the wheel or just change the color of the stitch. Maybe even add some suede/alcantara....anything you'd like. Enjoy!!
Installed pics coming in a day or two...
Its for a g37 coupe....as far as increasing the thickness. Its not something I can do yet. I've never done it and I'm not even sure what type of padding to use to make it thicker. I need to look into it because I'd really like to offer that as a service. I'll get it one day, just need to research.
Its pretty easy actually....
Disconnect battery.
Remove 2 t30 torx screws on the sides of the column to remove airbag.
Pull out airbag and disconnect.
Remove big 19mm nut holding wheel on and bam your done.
Oh and unplug harness in wheel.
Takes about 10 mins to do. 20 if you take your time.
Disconnect battery.
j
