STRI Racing Gauges (DSD - Stepping Motor Design) ** Low Cost / High Quality **
Old Dec 17, 2009 | 06:00 PM
RAVSPEC's Avatar
RAVSPEC
STRI gauges are only available in Imperial readings in US, please pm us for package pricing.
DSD Series
DSD Line FUNCTION - (Stepping Motor Design)
- User Preset Warning
- Peak Recall
- Auto Self Calibration
- 270 Degree Sweep
- Short circuit auto detect
- Sequential open / closing mode
- Dimmer function
- High brightness LED
- Light weight aluminum casing.
- All sensors included
- Mounting solution included
- Available in smoke lens - black or white LED backlight
- Available in white face - amber LED back light
- Available in black face - white LED back light
- Available in 52mm or 60mm size
Boost (2 bar) - $139.00 (electronic gauge)
PSI Unit
Boost (3 bar) - $159.00 (electronic gauge)
PSI Unit
EGT - $145.00 (electronic gauge)
Fahrenheit Unit
Oil Pressure - $169.00 (electronic gauge)
PSI Unit
Oil Temp - $109.00 (electronic gauge)
Fahrenheit Unit
Fuel Pressure - $169.00 (electronic gauge)
PSI Unit
Water Temp - $109.00 (electronic gauge)
Fahrenheit Unit
Tach - $99.00 (electronic gauge)
Voltmeter - $99.00 (electronic gauge)
X Line FUNCTION (**Non-Stepping Motor)
- Factory Preset Warning
- 270 Degree Sweep
- Start up open mode
- Dimmer function
- Available in black face, white face or smoke lens
- Available in white or amber LED backlight
Boost - $59.00 (mechanical gauge)
PSI Unit
EGT - $109.00 (electronic gauge)
Fahrenheit Unit
Oil Pressure - $79.00 (electronic gauge)
PSI Unit
Oil Temp - $69.00 (electronic gauge)
Fahrenheit Unit
Fuel Pressure - $59.00 (electronic gauge)
PSI Unit
Water Temp - $69.00 (electronic gauge)
Fahrenheit Unit
Tach - $59.00 (electronic gauge)
Voltmeter - $59.00 (electronic gauge)
Vacuum - $59.00 (mechanical gauge)
PSI Unit
Official Website: STRI Motorsport Electronics
Thank you.
JRW370
Buying & Leasing
Apr 8, 2019 09:24 PM
Detailed Image
Lighting/Cleaning Products
Aug 29, 2015 09:21 PM
m3clubracer
Aug 26, 2015 07:36 AM
Detailed Image
Aug 17, 2015 02:42 PM
