Help P2098 Code after Installing Test Pipes
Old Aug 16, 2021 | 06:21 PM
ForgedG37s's Avatar
ForgedG37s
So I had this shop install 1320 Resonated Test Pipes on my 2013 G37s Coupe 6MT. About a week or 2 later, I got a Service Engine Light which read P2098. (Post Catalyst Fuel Trim System Too Lean Bank 2). I was doing some research and was worried about the car running Lean which I know is bad for the car, I brought it to the shops attention and he said that he some extensions would do the trick and that I should not worry. What do you guys think about this? Any advise or tips? Where exactly is BANK 2?
I also want to add that during the install, I believe the shop damaged one of the sensors, and I had to get a replacement. It was upstream I believe? The passenger side sensor close to the headers. After the install, there were no codes for a week or 2, then that was when the P2098 code came up.
Only mods during time of install was Beluga Racing Axelback. Again any tips/thoughts would be greatly appreciated.
Old Aug 17, 2021 | 04:22 PM
Kpmikey808's Avatar
Kpmikey808
Tbh most of the time u will need a tune to get rid of check engine light- every car is different- some cars throw a code & some don’t - I had similar motordyne art pipes & it threw a code
Old Aug 17, 2021 | 05:10 PM
RMB5190's Avatar
RMB5190
Bank 2 = post cat
Extensions may work. As it sits, car is not reading a large enough difference from bank one to bank two.
Tune WILL NOT fix this issue. Tuners cannot turn off the sensors. In the event the sensors are off, you will still fail emissions because the system will show as 'not ready'.
Old Aug 17, 2021 | 07:24 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Bank 1= Passenger Side= Cylinders 1,3,5.
Bank 2= Driver Side= Cylinders 2,4,6.
Upstream "pre-cat" sensors are A/F sensors
Downstream "post-cat" sensors are O2 sensors
Old Aug 19, 2021 | 06:04 PM
ForgedG37s's Avatar
ForgedG37s
Thankyou for the reply.
Old Aug 19, 2021 | 06:05 PM
ForgedG37s's Avatar
ForgedG37s
Originally Posted by RMB5190
Bank 2 = post cat
Thanks for the info, do you think this CODE is bad and that if I keep driving with this specific code, then its bad?
Old Aug 19, 2021 | 06:06 PM
ForgedG37s's Avatar
ForgedG37s
Awesome thankyou for the info!
Old Aug 19, 2021 | 07:24 PM
RMB5190's Avatar
RMB5190
Nope. Doesn't effect health or performance. Just won't pass emissions.
Old Aug 22, 2021 | 02:23 AM
ForgedG37s's Avatar
ForgedG37s
Thanks for the reply!
Old Aug 22, 2021 | 02:25 AM
ForgedG37s's Avatar
ForgedG37s
Got the spacers put on today, hope the code doesn't come back. Heres a pic of before and after with and without the O2 spacer.
Before Spacer
After Spacer
Old Feb 12, 2024 | 08:55 AM
wrkls_'s Avatar
wrkls_
Before Spacer
After Spacer
Did this fix it? I’m getting codes p2098 and p2096.
Alvinhui
Jun 14, 2011 01:54 PM
G37Sam
Intake and Exhaust
Feb 9, 2009 01:31 PM
