Dimensions of helmholtz resonator on Motordyne
Old Jun 21, 2021 | 11:47 AM
spoolin03's Avatar
spoolin03
Hi, I was wondering if anyone with the Motordyne Shockwave exhaust system could measure the dimensions of the helmholtz / quarter wave resonator at the end of the exhaust (the big can).
reason being I have drone and I want to attach the same effective device to my exhaust to beat down on the drone
greatly appreciated
Old Jun 22, 2021 | 09:07 AM
projectpanda13's Avatar
projectpanda13
I don't know the full science behind tuning an exhaust with helmholtz but remember reading that the length of the resonator and location is based on the the drone range in the rpm and frequency you are targeting.
not sure how Shawn decided the location and dimension of my resonator but my exhaust does't have any drone.
Old Jun 22, 2021 | 11:04 AM
spoolin03's Avatar
spoolin03
^^ That's a pretty sweet looking exhaust. Custom?
I feel like single exit exhausts perform the best for mid range and up top
Does your car have good pick up on the lower rpms? (below 3k rpm)
Old Jun 22, 2021 | 11:10 AM
projectpanda13
It did for sure, feeling wise, no dyno to back me up. I originally started out with a Top Speed exhaust. The diameter at the y inlet and dual piping were 2.375" if i remember correctly. I then switched to a Motordyne exhaust, 3.0" merge then dual 3.0" al the way back. I didn't feel any difference during driving. Siwtching from the dual 3.0" to my current 3.5" single was very noticeable. My wife also noticed it too.
Old Jun 22, 2021 | 12:26 PM
spoolin03's Avatar
spoolin03
^^ You had the Motordyne Shockwave system? Are you on HFC's or test pipes or just stock cats?
Old Jun 22, 2021 | 01:23 PM
projectpanda13
yea, I had it with anti-reversion test pipes.
Old Jun 22, 2021 | 03:56 PM
spoolin03's Avatar
spoolin03
hmm so you're saying that single 3.5 inch is the way to go...
Old Jun 22, 2021 | 03:58 PM
projectpanda13
i wouldn't recommend 3.5". I only did this because i was planing for boost and wanted the extra head room. If you want to go single exit, i would suggest sticking with the standard 3.0"
Old Sep 28, 2022 | 01:27 AM
Avery Madrigal's Avatar
Avery Madrigal
did you go with the resonated y pipe too and mid pipe ? Planning on going back to single
Old Sep 28, 2022 | 02:39 PM
projectpanda13
i went with a dual resonated y pipe after the purchase of that exhaust. its a matching 3.5" with 3" inlets. The inlets are way bigger than i'd like but he had a hard time making the transition with the resonators.
I'm considering swapping out the current resonator in the mid pipe for something longer but will way until I get my engine up and running to hear how it currently sounds.
Runs On Water
Jun 2, 2021 04:21 PM
Nyzflyyguy
Mar 28, 2020 05:52 PM
Marcos Perez
Jul 31, 2019 09:11 AM
PNW_IPL
Sep 5, 2016 09:48 AM
leanlikeacello
May 20, 2016 05:53 PM
