Help I think I broke my car help me plz
Old Jun 26, 2019 | 12:37 PM
WhatsupG's Avatar
WhatsupG
I just changed my spark plugs and now I have a check engine light the slip light and the vdc light on and when I press on the gas pedal the rpms only go to maybe 1100. Has anyone had a problem like this before ?
Old Jun 26, 2019 | 12:44 PM
Evorus5's Avatar
Evorus5
The car is in limp mode. Is the car throwing out any codes?
Old Jun 26, 2019 | 12:46 PM
WhatsupG's Avatar
WhatsupG
I can’t take it to have the codes read but what is limp mode ?
Old Jun 26, 2019 | 12:52 PM
Evorus5's Avatar
Evorus5
If you can go to an AutoZone/O'Riley's to get a reader ~ $50 instead of taking the car and paying to get checked. It'll help in the future
Limp mode Reduces the power to engine and transmission and only lets it rev to a certain rpm so you don't damage them.
First time I got limp mode was in my g35, I had just cleaned my intake cones and they were still a bit wet after I put them back. Took it for a test and the car wouldn't let me go passed 2.5k RPM
Make sure that your spark plugs and coul packs are all seated and torqued down properly.
If you did nothing else to the car then your problem lies in what you touched.
Old Jun 26, 2019 | 01:14 PM
WhatsupG's Avatar
WhatsupG
Do u know how to take it out of limp mode ? Or what codes I should look for? I did get a code for sensor on the throttle body a while back but I cleaned them and it eventually went away
Old Jun 26, 2019 | 01:18 PM
Evorus5's Avatar
Evorus5
It will not come out of limp mode until you address the problem. And I wouldn't try to take it out of limp mode since the car is protecting itself from further damage. You need to check the codes first and then address them.
Again, I would make sure everything is seated properly on what you removed.
I've changed my spark plugs multiple times and have never had a problem while putting everything back to spec
Old Jun 26, 2019 | 01:22 PM
WhatsupG's Avatar
WhatsupG
Ok I got u thanks man
Old Jun 26, 2019 | 02:02 PM
Surfnazi's Avatar
Surfnazi
Sounds like you forgot to plug a sensor back in like maf
Old Jun 27, 2019 | 11:43 AM
Evorus5's Avatar
Evorus5
Oh yeah. Didn't even think of this. That's probably the problem
Was it resolved op ?
Old Jun 27, 2019 | 11:53 AM
Surfnazi's Avatar
Surfnazi
Since you have to remove intakes and throttle body to do all 6 plugs you probably at end rushed and forgot to plug back in sensors
Old Jun 27, 2019 | 02:30 PM
WhatsupG's Avatar
WhatsupG
That’s exactly what I did smh it was the the plug to the sensor on the throttle body passenger side. Thanks for the help tho
Old Jun 27, 2019 | 11:33 PM
slartibartfast's Avatar
slartibartfast
Appreciate you letting us know what the problem was. It'll help others (prolly even me).
Old Jul 1, 2019 | 12:27 PM
Surfnazi's Avatar
Surfnazi
Did you clean the contacts of the sensor and plug then put a little dilithium grease
Old Jul 1, 2019 | 12:35 PM
And no need to spend $50, these work fine!
https://www.ebay.com/itm/Mini-LCD-Ve...r/362665201538
GTLAW
Jan 29, 2011 08:58 PM
bxbadboyy88
General Tech Questions
Apr 20, 2009 08:51 PM
