Question about O2 senior
Old Oct 6, 2018 | 03:23 PM
703Y's Avatar
703Y
Okay i just recently put in cat less test pipe and i got a check engine light, witch I already knew that was going to happen btw, but is there a way to get away the check engine light ?
Old Oct 6, 2018 | 06:20 PM
takeapieandrun's Avatar
takeapieandrun
Use an OBD2 reader and clear the code
Old Oct 9, 2018 | 03:41 PM
axis.'s Avatar
axis.
If you want a more permanent solution you need to get an O2 bung extender and weld that onto the test pipe so that the sensor sits further away from the air flow. I got mine from eBay and problem was solved
Old Oct 9, 2018 | 09:08 PM
They make those extended O2 ports that screw on too, about 3" long give or take, and they go counter to the exhaust flow direction for more effective CEL avoidance
