ART pipe Hardware
Old 02-16-2018, 12:05 AM
QuinnDEskimo
QuinnDEskimo's Avatar
ART pipe Hardware
I recently bought some Motordyne ART pipes used so I don't have hardware. Getting ready to install but am missing some hardware. I've already purchased the 3 bolt Z1 gaskets (cat to header) and replacement OEM 2 bolt gaskets (cat to y-pipe). The only thing I don't have is the bolts and nuts for the cat to header side. Does anyone have the specs of the nut and bolt sizes for the 3 bolt side of the ART to header side that need to be used? Thanks in advance.
Old 02-16-2018, 12:50 PM
QuinnDEskimo
Anyone??
Kpmikey808 (06-30-2020)
Old 02-16-2018, 01:18 PM
PNW_IPL
PNW_IPL's Avatar
First off the ART pipes use the oem ring gasket and you should NOT be using the z1 gasket for the header.
second take a pipe with you to hardware store find stainless bolts that fit in the hole and correlating nuts. Make sure they'e stainless. For one bolt on each side you reuse oem nut as the stud is on the header not removable for install so you just need 4 bolts and corresponding nuts. Get bolts and nuts with 14mm or so head.
Old 02-16-2018, 01:27 PM
QuinnDEskimo
I notice you just listed yours (ART pipes) for sale in classifieds. Mind me asking why you're getting rid of them so quickly? Also curious for the reasoning for not using the Z1 gaskets and what is the intended purpose of the Z1 gaskets?
Old 02-16-2018, 01:30 PM
PNW_IPL
PNW_IPL's Avatar
ART pipes use the oem ring gasket pictured. No other gasket goes on.
QuinnDEskimo (02-16-2018)
PNW_IPL
PNW_IPL's Avatar
I'm planning on going back to single tomei and too loud with test pipes or hfc for my liking.
Old 02-16-2018, 01:35 PM
QuinnDEskimo
Ahhh, I see. Thank you! I'll have to take a look at them when I get home now. Don't be surprised if you see an ad for (2) Z1 header to cat metal gaskets in the classifieds soon. (they weren't cheap either).DOH!
Old 02-16-2018, 01:38 PM
PNW_IPL
PNW_IPL's Avatar
no problem. They actually don't seal very well either. Too thin. Glws. Good luck with hardware shouldn't be too difficult as your basically choosing bolt and nut that fit through the pre drilled holes in ART pipes.
Old 02-16-2018, 01:46 PM
QuinnDEskimo
Any suggestions on getting them to seal up better? How'd you get yours to not leak?
Old 02-16-2018, 01:48 PM
PNW_IPL
PNW_IPL's Avatar
I had ARTpipes so I didn't need them. They came with z1 hfc I bought and I bought different gaskets for them.
Old 02-16-2018, 01:51 PM
QuinnDEskimo
The FSM shows a gasket between the cat and header. I'm confused.
PNW_IPL
PNW_IPL's Avatar
What car do you have?
Old 02-16-2018, 01:53 PM
PNW_IPL
PNW_IPL's Avatar
I'm beating a dead horse. That fsm shows 350z DE or g35 with the DE. The 07-08 g and Z with the HR have ring as well as all g37 and 370z. So with that said.
Old 02-16-2018, 01:54 PM
QuinnDEskimo
It's a '12 sedan. Sorry if i'm killing you here.
QuinnDEskimo
Gotcha so the FSM is incorrect is what you're saying. Thanks.
Quick Reply: ART pipe Hardware
