Tomei on awd coupe
Old Feb 14, 2018 | 03:10 AM
Maxw303's Avatar
Maxw303
Tomei on awd coupe
I have a 11 G37xs coupe and have been in the market for a new catback exhaust. I’ve been debating between the ark grip and the Tomei Expreme TI. I know the Ark grip will bolt on no problem with my awd coupe. Now the Tomei is really where my heart is but I know my transfer case will be in the way. Is the transfer case the only obstacle to fit the exhaust? If anyone has done this successfully how much did it cost to retrofit and if you have pictures of finished product that would be sick. Thanks guys
Old Aug 10, 2019 | 09:02 PM
Japan's Avatar
Japan
Did you solve this? Thanks.
Old Aug 11, 2019 | 09:16 AM
PNW_IPL's Avatar
PNW_IPL
It will work. You just need an extension pipe. The difference in awd to rwd is in the Y pipe.
Old Aug 12, 2019 | 08:33 PM
Japan's Avatar
Japan
thanks for swift reply I always see you on every post lol. Are you running a tomei? I had a muffler delete so neighbors are used to that, but Im only worried about cold start? Does the silencer actually help slightly?
Old Aug 12, 2019 | 10:59 PM
PNW_IPL's Avatar
PNW_IPL
If you have stock cats it's not that loud. Silencer helps alot. Also resonated Y pipe helps alot though I dont think itll fit awd the y pipe that is
Old Aug 13, 2019 | 06:35 AM
Japan's Avatar
Japan
Someone said all you need is longer than normal 12' extension pipe but I have fast intentions resonated hfc and a manzo y pipe haven't installed yet
Maxw303
Intake and Exhaust
Feb 14, 2018 03:13 AM
Bo0m
Feb 28, 2013 10:32 AM
gduece22
Feb 12, 2011 12:56 AM
