Tool to make catalytic converter removal easier
Has anyone tried to use a torque adapter box end wrenches to remove the catalytic converter to header bolts? I used the tried and true method with a 3' extension and a 14mm quality snap-on flexible joint socket.
I've moved on to a different car that has a similar, hard to reach bolt and a company called AWE makes a small tool to facilitate the removal of that one difficult bolt. So the demon bolt is not exclusive to the Infiniti, LOL. They basically machine a torque adapter wrench. You can buy entire sets, in metric, and I'm sure it would negate the need to go from the engine bay and you'd be able to do everything underneath the car.
I ended up buying a set from Amazon as the AWE tool, with shipping, came out to over $50.
Just thought it might help. You may be able to just purchase one 14mm torque adapter wrench off of eBay. I thought it'd be nice to have a set.
Hope this helps!
demon bolt, cat removal, high flow cats, hfc, test pipe, headers
Hope this helps!
I trust 6 point only for any demon bolt, cat removal, high flow cat stuff.
Lol, my exhaust bolts don't even have heads on them anymore. They just rusted themselves round. If i ever have to take the cats off it's gonna be with a chisel and a power drill
Bravo at (11-30-2017)
