02 sensor wiring extension
Old Oct 30, 2017 | 10:49 PM
Calg37USMC's Avatar
Calg37USMC
Is this available? I tried searching and came up with noting. I need these since I’ve melted through two already. With the MD Long tubes this is required. Thanks for your time.
Old Oct 31, 2017 | 08:18 AM
Calg37USMC's Avatar
Calg37USMC
Bump it up.
Old Oct 31, 2017 | 09:27 AM
The Pope's Avatar
The Pope
Why not just cut and splice in enough wire to give you the length that you need?
Old Oct 31, 2017 | 10:26 AM
Calg37USMC's Avatar
Calg37USMC
I already did that was wondering if there was an aftermarket product? Thanks for the reply.
Old Nov 1, 2017 | 06:22 AM
The Pope's Avatar
The Pope
Google comes up with several. You'd just need to make sure you get one with the correct connectors.
https://www.google.com/search?q=infi...hrome&ie=UTF-8
Old Nov 10, 2017 | 12:51 AM
Calg37USMC's Avatar
Calg37USMC
Anyone know the stock gauge size for the 02 sensor wires? 18 or 16?
Old Nov 10, 2017 | 06:17 AM
The Pope's Avatar
The Pope
^ Good question.
I don't know the size either and if I had to guess, it would be closer to 20.
I'm going to be replacing one of the secondary O2's soon. If nobody has answered the question before then, I'll cut and measure the wires of the O2 that I'm removing.
