P0455 Purge Control Valve Location?
Old 05-02-2017, 09:03 AM
babskyline
babskyline's Avatar
Recently I have had a P0455(EVAP Control System Gross Leak) come up.
So far I have already:
-Replaced gas cap (OEM) and disconnected battery to reset SES light. but the light came back on again.
Next to Check:
-Purge Control Valve
-I want to check the Purge Control Valve but I cannot find any picture or insight online or in the forums that points to the exact location. Any insight?
Cheers,
Babskyline
Old 05-02-2017, 11:35 AM
zer099
zer099's Avatar
If I recall it's in the back behind the drivers rear wheel under the trunk.
Old 05-03-2017, 07:50 PM
babskyline
babskyline's Avatar
Hmmm, I did not see anything. Could it be under the rear skid plate?
Old 05-03-2017, 07:51 PM
babskyline
babskyline's Avatar
Does anyone have a picture or diagram to help a brotha? Thanks!
Old 05-04-2017, 12:51 PM
zer099
zer099's Avatar
My bad, EVAP canister purge volume control solenoid valve is located at the back of your upper intake manifold/plenum. The EVAP control system pressure sensor is behind the rear wheel; and it was the passenger's side not driver's. Apologies on that.
FSM
Start at page 83 for visual reference to locations.
Old 06-30-2019, 07:52 AM
GodlikeRage
GodlikeRage's Avatar
Did you ever fix this issue?
Old 07-03-2019, 02:28 PM
flipmode007
flipmode007's Avatar
I had that issue too, all I did is go to the scrap and get a solenoid from the EVAP and swap it on your car and the code was gone way cheaper then buying a brand new EVAP
Old 07-03-2019, 02:41 PM
GodlikeRage
How much you pay for it?
