I'm Stuck :(
Old Aug 7, 2016 | 12:42 PM
WhiteVQ37's Avatar
WhiteVQ37
Unhappy I'm Stuck :(
So I bought a Motordyne M370 that i was planning on installing, which I did yesterday. Made my own T-fittings to connect all the vacuum lines. Went to start runs like crap. Idling all over the place dips low, shakes, shoots back up. Just a nightmare. Reset ECu throttle position relearn, IAC relearn no avail. So this morning I said forget it, going back to stock because I need my car for work. Put everything back the way it was when I took it off, still idling poorly.
So again, peddle dance it up reset everything I need to reset, still running poorly. So I got it to hold(not very well) just as in not dying on me and I started spraying Throttle body cleaner around the intake plenum and it goes from almost dying to shooting up. I did this because I heard a hissing noise from the driver side.
My question is what should I do honestly? I've been searching and searching for the torque specs for the oem intake plenum and haven't found anything for our car. even checked around the FSM and nothing I could see. Any help would be great everyone :'(
Old Aug 7, 2016 | 12:51 PM
WhiteVQ37's Avatar
WhiteVQ37
Of course I found the ft-lb specs now, it's 8 ft-lbs. I don't have a wrench that goes that low. I know they're tight enough, possible even too tight, but I know nothing cracked or anything like that. Blah, this has been a terrible weekend.
Old Aug 8, 2016 | 11:07 AM
Kris9884's Avatar
Kris9884
Sounds like a vacuum leak if the only constant variables are the hoses and clamps. I would also check the MAF's and plugs. To me, those are the only things it could be unless you took more things apart that you didn't need to.
Old Aug 10, 2016 | 08:21 AM
WhiteVQ37's Avatar
WhiteVQ37
I found out since my car is in pieces now lol, that when I over-tightened the plenum bolts it must have cracked the lower plenum somehow. there is a hole in the side of it right by the threads fro the bolt. Getting a new lower plenum locally for cheap, going to get it milled to spec, new gaskets on the way as well. Thanks for your replay though!
Old Aug 10, 2016 | 09:15 AM
Kris9884's Avatar
Kris9884
Oh man :/ At least you found it and learned your lesson, use the manuals ft/lb specs bro!
crispy_11
Feb 8, 2024 09:01 AM
DawsonSkalsky
Apr 1, 2016 11:21 AM
